Question about Neff Ovens
How to replace a thermostat tetrablock in my Neff Oven
My NEFF oven thermostat (tetrablock) needs replacement cause one of the four burners(the biggest one) is heating at maximum regardless i select 1 or 9 with the knob. I need a dissasembly/assembly manual to do it myself...cause the tetrablock thermostat is already expensive. E-nr: E1442N0GR/01
  • Dim Milos
    Dim Milos May 14, 2014
    I could also follow a guide on how i could reach this thermostat compartment
4 Suggested Answers
  • 228 Answers
SOURCE: My Neff U1721 oven does not heat up, Element
YOU CAN BYPASS IT HOWEVER BEAR IN MY THIS IS A SAFTEY DEVICE AN MAY HAVE FAILED BECAUSE OVEN OVERHEATED,( FIRE RISK PRESENT) IF THIS IS THE CASE, A BYPASS SHOULD BE CONSIDERD VERY TEMPORARY.
Posted on Jun 15, 2010
barkencoa
  • 3463 Answers
SOURCE: is it quite easy to replace the element in my
Very easy, just remove cover at rear of inner oven compartment, you will see the element there.
Posted on Sep 20, 2010
SOURCE: Neff oven U1421N0GB/01 built in
Hi most often when a problem like this arises the Thermistor, or the thermostat controller, is faulty. most often just the Thermistor, the actual little element that detects the temperature.This needs to be replaced first, and if the condition is not helped or fixed, then it is the thermostat controller that's faulty and must be replaced.
The Thermistor can be tested with an OHM meter to determine functionality or not, usually it is a few KOhms, it is faulty if Open circuit, Closed, short circuit, or a very high resistance, that will NOT change linearly with temperature change.
The parts are easily available via sellers on the internet.However to be able to obtain the parts one must have the manufacturers parts numbers, these usually are only available from the service manual. if wishing to DIY repair, then this manual must be obtained, usually again via the internet.
It may indeed be less expensive and time consuming to engage the services of a serviceman and get a "Quote" for the job, and go from there.
Posted on Apr 25, 2011
Tip
Common heating faults with Neff B1644 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1644 Electric Single Oven
Tip
Common heating faults with Neff B1428 single oven
on Jan 19, 2010 | Neff B1428 Nostalgic Single circotherm...
HOW DO YOU REMOVE CONTROL KNOBS TO REPLACE THE ON THE NEFF B1451 OVEN
I have a Neff B1451 oven and have removed the thermostat knob just by pulling and wiggling it. Thats all you do. If then you want to rpelace the thermostat, there are two screws holding the unit onto the oven which are accessed by taking the silver metal shrouds off first.
Jun 24, 2011 | Neff B1432 Single circotherm plus Electric...
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Tip
Common heating faults with Neff U1421 Double oven,
on Jan 19, 2010 | Neff U1421 Double circotherm Electric Oven
Tip
Neff U1452 Double oven Common heating faults,
For all Free appliance repair videos visit our VIDEOTUTORIALS
1, If the Neff fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1452 Double circotherm plus Electric...
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
Tip
Common heating faults with Neff B1421 Electric Single Oven
on Jan 19, 2010 | Neff B1421 Electric Single Oven
Tip
Common Heating faults Neff U1721 Electric Oven
on Jan 19, 2010 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
32 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
