Question about Soleus KY-34 Portable Air Conditioner
Exhaust hose so were do I get an exhaust hose
  • 682 Answers
I would try any plumbing/heating store.
Posted on May 14, 2014
Where can in get a set of exhaust/intake hoses for a danby dpac120068 air conditioner
Is there a reason not to just go to the Danby site? Support Danby includes phone support, email and "Find Parts" Even if their source is out you should at least be able to find the correct part number, then Google Danby (part number).
You could also look to see if generic flexible vinyl tubing/hose can be substituted. It's doubtful that Danby created their own hoses.
Jun 09, 2016 | Danby Heating & Cooling
Portable air conditioner rattling
not sure i use mine without exhaust hose
Feb 21, 2014 | Amana AP095R Portable Air Conditioner
Constipation
Can you check the exhaust water hose by looking straight down the drain in the sink where a dishwasher exhaust hose is normally attached, to see if you have any water leaving the dishwasher at all? Can you remove the exhaust hose, and put in a pan to see if you can get some water to flow out? I am guessing you may have a clogged exhaust hose, or clogged sink attachment on the sink drain. After lot of use, debrea will build up in the exhaust hose. You might also consider cleaning the inlet valve filter, the collect sand from the water supply, and can clog after many year of service.
Dec 19, 2012 | Whirlpool Dishwashers
Amcor KF9000E portable air conditioner manual
My amcor kf9000e has stopped blowing cool air. What could be wrong with it?
May 18, 2012 | Amcor AF9000E Portable Air Conditioner
How do i change from vacuum to blower?
In order to change from suction to blowing, insert the hose into the
exhaust port of the vacuum cleaner.
The vacuum cleaner should have two ports, one which is for suction,
the other is an exhaust port. The exhaust port can be used for blowing
when the hose is inserted into it.
After inserting the hose into the exhaust port just turn on the switch.
Jan 17, 2011 | Black & Decker UV200 Wet/Dry Vacuum
There is a black tubing where the exhaust hose goes therefore i can not get the exhaust hose on.what is this black hose for? do i have to reroute this?
There is no exhaust hose on a A/C unit. That black hose, or seal tight, has wires in it. Are you talking about the hose from the drain pan. If that is what you are talking about. Put a water hose on the drain and blow out the blockage. make sure the drain hose by the condensor outside is not barried. Put a 90% fitting on the end of the out side drain hose faceing up, to keep water in it to keep out critters.
Jun 21, 2010 | Heating & Cooling
EGR VALVE 1999 MERCURY COUGER
SECTION 303-08: Engine Emission Control 1999 Cougar Workshop Manual REMOVAL AND INSTALLATION Exhaust Gas Recirculation (EGR) Valve Removal
  1. Remove the air cleaner outlet tube.
    1. Disconnect the intake air bypass hose.
    1. Disconnect the positive crankcase ventilation hoses.
  1. Disconnect the tube from the exhaust gas recirculation valve.
  1. Remove the exhaust gas recirculation valve.
    • Disconnect the vacuum hose.
Installation
  1. sxu~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: When cleaning the gasket faces, do not allow debris to enter the intake manifold or exhaust gas recirculation valve.
    Clean the gasket faces of the intake manifold and exhaust gas recirculation valve.
  1. Install a new exhaust gas recirculation valve gasket.
  1. Position the EGR valve and install the bolts.
    • Install the vacuum hose.
  1. Connect the EGR tube.
  1. Install the idle air control valve. For additional information, refer to Section 303-14A . For additional information, refer to Section 303-14B .
Sep 15, 2009 | 1999 Mercury Cougar
My whirl pool dryer has to be turned on bout 3 to 4 times
Ok, check the exhaust hose for obstructions. make sure the blower assembly is not clogged and, the hose is clear of any debris. the exhaust hose should blow out hot air forcefully. if the force of the air isn't blowing hard, it will not create a suitable drying environment for the element. this poor ventilation will also damage the heating element or burner Assembly.
Now, if there is sufficient air flow out of the exhaust hose, this will confirm control failure. replace the dryness sensor and control board in this case.
Here's a quick way to test for clogs. take the hose of the backside of the dryer then, start the cycle. if the drum sorts to become hot after a few minutes with the exhaust hose removed form the back of the unit, this will confirm a major block in the hose or blower assembly.
May 29, 2009 | Whirlpool Dryers
Dryer exhaust not blowing out of vent tubing
open it up follow the vent,it is either blocked or came off.
Dec 08, 2008 | Splendide 2100 Vented Washer-Dryer
Exhaust Hose
No, they have different fittings.
Aug 25, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Soleus KY-34 Portable Air Conditioner Logo
61 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
