Voltas ac splite type
After running of 10minutes . AC stops cooling although compressor is running without load.
  • 682 Answers
Possibly low Freon issue. It is really hard to know without checking it.
Posted on May 14, 2014
  • 124 Answers
SOURCE: High Pressure cutoff
YOUR OUTDOOR FAN MOTOR SHOULD NEVER SHUT OFF IN THE AC MODE. IT IS SUPPOSED TO SHUT OFF IN THE HEAT MODE WHEN ITS IN DEFROST. IF THE UNIT IS RUNNING IN COOL AND THE OUTSIDE MOTOR QUITS ,THE COMPRESSOR WILL QUIT SOON AFTER. EITHER THE RUN CAPACITOR FOR THE FAN IS BAD OR THE FAN MOTOR ITSELF IS BAD, IF CAP IS GOOD THEN THE MOTOR IS At FAULT. THE OUTDOOR PRESSURE SWITCH CAN ALSO OPEN IF THE INDOOR FAN MOTOR FAILS IN HEAT OR THE FILTER IS PLUM NASTY in heat OR THE INDOOR COIL IS PLUGGED UP in heat.. THE PRESSURE SWITCH USUALLY TRIPS AT 400 TO 425 SO ITS WORKING CORRECTLY. YOU MAY BE CONFUSING THE ISSUE SAYING THAT THE AIR IS HOT AND COLD INSIDE. IT IS COLD WHEN AC IS RUNNING HOT WHEN HEAT PUMP IS RUNNING IN HEAT BUT ESSENTIALLY not cold or hot if compressor isn't running, but a lot of folks describe the lack of cold air as hot when the compressor isnt running. but it basically is warm or house air temp.you test the capacitor with a capacitor tester or take it to motor shop and let them test it. odds are its a 5 , 7.5 or a 10. it should test within 10 % of rated value . ask for a RESCUE brand replacement motor. they are great ,reversable etc.carefully oil and sand the motor shaft and note exactly where the blade was located in relation to the grill so you get it back just the same. usually they wire up black to a leg of 220 power. white to the other leg of 220 power. brown and brown with white stripe to the capacitor.you can also pull whole fan shroud assembly on some units and take whole thing to motor shop and let them test motor cap, replace and all you do is return to unit and connect two power leads,
Posted on Oct 26, 2008
louislevel_2
  • 374 Answers
SOURCE: Samsung Ac compressor stops after 20 minutes and fan keep running
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Posted on Mar 16, 2009
  • 587 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 5 Answers
SOURCE: 1.5T Voltas Vetris window AC. Ice formation
I think the more likely problem is that the unit is slightly short of gas\ refrigerant, which is a common cause of icing up evaporator coils and this sound you describe. First check that the air filter is clean. Another cause could be the defrost sensor is faulty, but I would think not. Some ice isn't actually a bad thing, but quite common as long as it doesn't form over too much of the coil, or get too thick.
Posted on Aug 16, 2009
  • 296 Answers
SOURCE: my central ac unit never shuts off, the fan blow
no..check the fan relay/board
Posted on Feb 17, 2010
Voltas window ac 1.5ton Power is there but unit doesnt start.
Several places to look. First is the power switch. If the fan runs look next to the temperature dial. That is the thermostat. It could be stopping power to the compressor. If that checks out there is a safety switch on the compressor under tha plastic cover where the wires connect to it. There is also a possibility that the start capacitor is bad.
Jul 16, 2014 | Heating & Cooling
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
Hyundai accent 2002 car high temparature during start ac
check see if cooling fan running could have faulty cooling fan relay or fuse.if cooling fan dont run when ac on car will overheat.AC COMPRESSOR PUT LOAD ON ENGINE.
Sep 06, 2012 | 2001 Hyundai Accent
Voltas Vertis AC not cooling
my voltas split a/c is showing CL on closing please help me out
Jul 04, 2012 | Heating & Cooling
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
On ac with out remote
Lift the front panel on the indoor unit and press the small button on the right hand side near the electrical cover
Apr 23, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
AC is just blowing air. The compressor doesn't kick on.
no freon.. pressure test w/ nitrogen. 8000 btus is now junk. Spend the money on new unit otherwise find the leak. It leaked out thats why the compressor will never go on. Once you add freon she'll turn on...same as car.
Dont buy that name brand again. best of luck to you
Aug 17, 2009 | LG Heat cool Window Air Conditioner
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
