Question about Canon PIXMA MG3550 Inkjet Multifunction Printer - Colour - Photo Print - Desktop Copier, Printer, Scanner - 9.9 ipm Mono/5.7 ipm Color Print ISO - 44 Second Photo - 4800 x 1200 dpi Print ipm Mono/2.7 ipm Color Copy ISO - 1200 dpi Optical Scan - Automatic
The printer works fine from Windows including Scanner.When using photocopy from printer panel does not work.
  • 3 Answers
If you are not getting any error messages, I suspect you definitely have a printer hardware problem, especially if it prints fine from Windows. Best to contact Canon's technical support with this one
Posted on May 14, 2014
old marine
  • 1973 Answers
SOURCE: All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
Posted on May 21, 2008
preachw996
  • 1179 Answers
SOURCE: mx700 will not scan even if the printer works well
You will need to download and install the vista driver for this to work on your vista computer. XP & Vista drivers are not the same and that is the reason it will work on the XP computer but not on the Vista computer. Driver should be available from the hardware manufacturers website. Hope this helps.
Posted on Jul 08, 2009
  • 19 Answers
SOURCE: I can't find the drivers
http://support-asia.canon-asia.com/P/search?model=PIXMA+MP258&menu=download&filter=0&tagname=g_os&g_os=Mac%20OS%20X
Does that help? - a number of downloads on there.
Think you want... http://support-asia.canon-asia.com/contents/ASIA/EN/0100196901.html
Posted on Sep 18, 2010
muntejaya
  • 10421 Answers
SOURCE: Canon MP600R working on a
Please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
jay uth
Posted on Feb 12, 2011
zappanut
  • 959 Answers
SOURCE: when trying to transfer photos printer was fine, then transferred everything on its memory even though we already had it then kept asking to load memorycard when it was already in wont acknowledge any
Power off the printer and wait for 2 minutes.
Power the printer back up and access it thru the PC controls software and try to print something that way.
if this is no good , then I would access the printers web site at ;
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
Posted on Jan 13, 2012
What would make a printer only when making a copy or scanning put blue on paper? When printing its not there why?
The Dell 3115 (and Xerox 6180 multifunction, and Lexmark X560) all have a common problem with the INSIDE surface of the scanner platen attracting a deposit. This makes it a little 'cloudy' to look at, and produces a bluish tint to colour photocopies.
Print a test page from the printer that includes colours from all four cartridges. Then make 2 photocopies - one using the document feeder, and one using the flatbed. One may be better than the other - as a work-around.
The REAL solution is to clean the inside of the scanner platen (glass), but you must be very careful, otherwise you'll trash the printer. It is a very complex procedure to remove the scanner platen completely. It can (with great care) be lifted from the front, being very careful not to strain the cables. It can be cleaned successfully.
Apr 30, 2014 | Dell Printers:Dell MFP Color Laser 3115cn
Scanner function does not appear to work. All
i would say possibly you are missing out on something..because if the other functions particularly photocopying are working then this should work..as in if the photocopying function works then the scanner is ok cause basically in photocopying the machine scans then prints... perhaps check whether you are correctly following procedure to scan..most hp all in ones have a button on them that you press and it automatically initiates scanning and simultaneously the software on the pc is initiated..try this,if not then try reinstalling the hp software..hope this helps..regards
Jun 04, 2010 | HP Photosmart 2575 All-In-One Printer,...
I WANT TO USE THE SCANNER BUT, I DON'T NOW HOW, It go to the printer all the time, could you please help me ? I have the EPSOM STYLUS BX300F PROFESSIONAL, PRINTER,SCANNER,FAX,PHOTOCOPIER.
Basically, you can use the scanner in two ways. Please open the scanner cover and place the document or image you want to scan face down.
1. Press the SCAN button (color button = color scanning, black button = monochrome scanning). then your scanner will scan the document or image in the scanner tray.
2. Go to the scanner program installed in your computer when you installed the printer. Open it and then click the command button SCAN.
Note: Make sure that you installed the Scanner software when you installed the printer. Without the software, your scanner will not work. Please reinstall the printer including the scanner software.
Feb 06, 2010 | Epson Stylus Multifunction Inkjet Printer/...
SmarThru Office can't see scanner (nor can word)
Windows is using Window's default scan driver, so it's working only within Windows scan wizard feature. You will need to install the Scan Driver separately to work with SmarThru and other software. The Scan Driver is available at Samsung website.
Apr 16, 2009 | HP PSC 1350 All-In-One Thermal Printer
Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
Scanner problem
Try uninstalling and reinstalling the scannner. Scanner's can be tough. Try disconnecting USB cable and reconnecting too. How recently did the scanner work? Try reinstalling the scanner software/driver. Also see if you can trouble shoot by right clicking on scanner icon from control panel, scanner.
repost if none of these work. thanks.
Sep 02, 2008 | Sharp AL 1631 Copier
Print Okay , PhotoCopy Okay, Scanner Problem
If you are still having problems and are running windows vista what I had to do was go to this web site http://www.samsung.com/me/products/printer/multifunction/scx_4100.asp?page=Specifications and click on drivers in the box at the top and there is a separate scanner driver that has to be installed for it o work it has fixed my problem..
Nov 14, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Hp 1317 psc
you didn't describe your problem briefly. 1. Check if you photocopy anything, it is coming out correctly you are doing. it means your scanner is perfectly allright. 2. if you are not able to photocopy with this printer, it means your scanner is not working properly. But if it photocopying properly and in windows it is not scanning it means software is not working properly, try to arrange new software from anywhere and try.
Sep 24, 2007 | HP PSC 1315 All-In-One InkJet Printer
Scanner & black pages
The black printing usualy occurs when there is a faillure in the light, since your light is working fine, there may be a problem in the imaging device inside(camera) or the reflector. There is nothing wrong with the cartridge.
May 05, 2007 | HP PSC 1510 All-In-One InkJet Printer
Canon PIXMA MG3550 Inkjet Multifunction Printer - Colour - Photo Print - Desktop Copier, Printer, Scanner - 9.9 ipm Mono/5.7 ipm Color Print ISO - 44 Second Photo - 4800 x 1200 dpi Print ipm Mono/2.7 ipm Color Copy ISO - 1200 dpi Optical Scan - Automatic Logo
82 people viewed this question
old marine
old marine
