Question about Canon PIXMA MG3550 Inkjet Multifunction Printer - Colour - Photo Print - Desktop Copier, Printer, Scanner - 9.9 ipm Mono/5.7 ipm Color Print ISO - 44 Second Photo - 4800 x 1200 dpi Print ipm Mono/2.7 ipm Color Copy ISO - 1200 dpi Optical Scan - Automatic
SERVICE TOOL MG3550 - Canon PIXMA MG3550 Inkjet Multifunction Printer - Colour - Photo Print - Desktop Copier, Printer, Scanner - 9.9 ipm Mono/5.7 ipm Color Print ISO - 44 Second Photo - 4800 x 1200 dpi Print ipm Mono/2.7 ipm Color Copy ISO - 1200 dpi Optical Scan - Automatic
Ecu not responding in 2002 buick rendezvous. I lost my only key so I bought 2 from a locksmith but he was not able to program the keys. The device he hooked up to my buick said ecu not responding.
unfortunately your only option is the dealer ,
Connect a scan tool to the vehicle.
Turn ON the ignition, with the engine OFF.
Insure that all power consuming devices are turned OFF on the vehicle.
With a scan tool, select Request Info. under Service Programming System and follow the scan tool on-screen instructions.
Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions.
Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
With a master passkey III key, turn ON the ignition with the engine OFF.
With a scan tool, select Program ECU under Service Programming System.
At this point the scan tool must remain connected for the duration of the 10-minute relearn procedure.
Jul 08, 2017 | Buick Cars & Trucks
How to fix double vision print?
Hello
The duplicate print is a problem you can fix easy, only need...
1. calcium grease
2. and put in the iron making
with the next steps...
Solving problem of duplicate letters in Canon printers
http://www.en.rellenadodecartuchos.com/2015/11/solving-problem-of-duplicate-letters-in-canon-printers.html
Nov 19, 2015 | Canon PIXMA MG3550 Inkjet Multifunction...
What is my port number
All computers have serveral com ports and HDMI, so you have to set up one or the other to have printer work. You choose which port on computer. www.FREE-PPV.com
Mar 15, 2015 | Canon PIXMA MG3550 Inkjet Multifunction...
How do I scan a physical document on the mg3550
Change you loaded pixma print at play store? Then set printer to the device and your wi-fi network. Select the app and you will see scan. Place document on glass and select scan.
Feb 02, 2015 | Office Equipment & Supplies
I have downloaded pixma/maxify printing solutions app from web as not on google web store but cant open or delete it... I need it to register Canon mg3550 for google cloud print.
I dont know the chrome os is like. But if it has a settings button like you would on your S3 then my device then applications you can remove it there but if not then I cant help there but this is the link for google https://play.google.com/store/apps/details?id=jp.co.canon.bsd.ad.pixmaprint&hl=en
Sep 15, 2014 | Samsung Chromebook Series 3 XE303C12
Canon mg 3550 alignment problem?
Dear sir
I have encountered this problem on other printers. Try to clean the ribbon sensor found just above the head. It is a plastic digitizer strip used to align the head movement. Usually it has some grease on it just clean it with some cloth very gently.
Mark Borg
May 27, 2014 | Canon PIXMA MG3550 Inkjet Multifunction...
The printer works fine from Windows including Scanner.When using photocopy from printer panel does not work.
If you are not getting any error messages, I suspect you definitely have a printer hardware problem, especially if it prints fine from Windows. Best to contact Canon's technical support with this one
May 14, 2014 | Canon PIXMA MG3550 Inkjet Multifunction...
Finished the free trial...now have to log in every time. What's up with that?
Usually the free trial is offered for a certain period ... so that you can try the tool/service/software/website, etc., and decide whether you wish to purchase/subscribe/license the tool / service / software.
Since you didn't indicate what it is, I am not able to refer specifically to what it is ... i.e. a service, a tool/utility/software/website, etc. (Sorry).
At the end of the free trial period, it is not unusual for the tool/software/service provider to ask you to subscribe to the service or pay to use the software / tool / website. And, they usually make it cumbersome for you to continue using the service / software /tool/website, etc.... hoping to push you to decide to want to continue using it bad enough (or maybe until you're fed up with the troublesome / tedious process) ... to want to pay for it .
If you don't wish to pay for it, your other option is to stop using the "free trial" tool / software / website ... and/or uninstall the software / tool from your computer. If you're technically savvy, you may even be able to remove all traces of the tool / software / service identity (from your computer) ... and try to install / use the software / tool / service /website again ... for another free trial period.
If you can indicate what it is you're using (during the free trial period), I may be more specific about what is possible.
Nov 05, 2013 | Computers & Internet
Service tool for canon ip2772
How can i get canon ip2772 service tool?
Apr 20, 2013 | Canon PIXMA Office Equipment & Supplies
Canon PIXMA MG3550 Inkjet Multifunction Printer - Colour - Photo Print - Desktop Copier, Printer, Scanner - 9.9 ipm Mono/5.7 ipm Color Print ISO - 44 Second Photo - 4800 x 1200 dpi Print ipm Mono/2.7 ipm Color Copy ISO - 1200 dpi Optical Scan - Automatic Logo
615 people viewed this question
old marine
old marine
