Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Where is temp boost thermostat located on Frigidare FDB510LCS3? It shows up on the door parts list but the location is not shown.
2 Suggested Answers
  • 1462 Answers
SOURCE: FDB949GFB2 Frigidare Dishwasher
don't know this appliance but as a guide:
take top off and dryer manifold goes across the top of the machine. there are various stats mounted on the manifold. one or more may be resettable stats ie have a litle button in the middle. press the button to reset. if you have access to a multimeter, check continuity thro the stats as wee and check continuity thro the heater itself
Posted on Sep 05, 2008
Cooling sensor 2005 impala
Ask parts store to show you location chart. Generally, the coolant temp sensor will be near the thermostat housing.
Apr 30, 2015 | 2005 Chevrolet Impala
Thermostat location ed2fhgx
Your model does not have the old style thermostat. It uses a=> 12002355 Thermistor
and located inside the control panel and freezer compartment. The thermistors connect to the control board. Here is a parts list and the list shows the thermistors=> MFI2568AES.pdf I am here should you have questions, Sea Breeze
Nov 27, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
2000 Isuzu Trooper cannot find engine temp gage sensor
this is where it is at on a 1998-2000 3.5 V6
1997 3.2 V6
Nov 23, 2013 | Isuzu Trooper Cars & Trucks
Temp sensor 1996 toyota corolla location
'96 or '89... Usually near the thermostat location.
There is one for the computer and one for the temp gauge.
Ground one of the wires to see if the temp gauge "pegs".
Mar 06, 2013 | 1989 Toyota Corolla 2 Door
Where is the thermostate(sensor) located that controls the compressor - or is it the same as the sensor located by the door which show the temp on the outside indicator Thanks
The thermostat sensor is located in the top rear of the interior of the unit, if you locate the dial to change temps on the inside of the unit, the sensor is attached to it, you may have to pull your fridge apart to get to it, but it can be done.
Regards Russ
Mar 07, 2011 | Nor-Lake Freezer Norlake Refrigeration 6'...
2000 Buick LeSabre A/C blows hot out drivers vents and cold out passenger vents history codes are BO179output air temp sensor 2 short to ground or open,,BO234 Air mix door 1 range error,,,BO237 air mix...
Depending on the model, normally there is a door at the center of the air duct for the AC. It should be found underneath the dashboard at the center. Normally when the motor of the door is faulty you would not get the correct mix or will not get a constant air temp blowing on the two sides. Have the motor checked out. The other scenario is the thermostat or the temp sensor found near the same location towards the evaporator or the part where you can see the coils if you remove all the cover. Inspect the wiring to that part make sure that there is no exposed wire or loose wire. Either there is an issue with the wiring or the thermostat has gone bad. A bad thermostat would mean no signal to the AC which activates the door to send the correct air temp.
Apr 13, 2010 | Buick LeSabre Cars & Trucks
Check engine light on
Heater temp is a bit low but I don't know what the ambient temp was when you tested (the colder the outside air, the cooler the blower temp will be.) I'd definitely change the thermostat before doing anything else. Todays engines run @ about 210 degrees. If you've got a 160 thermostat in there, it won't ever get there. (will also mess with mpg.) Even the cheapest manuals contain locations for stuff like that. Everyone keeps changing locations, and I haven't worked on this stuff for a while, so I can't give you a location.
Yes there are other possible causes to your problem (blend doors etc) but I'd stick to the simple common stuff first!
Dec 31, 2008 | 2003 Saturn VUE
Sep 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Need to replace knobs on Frigidare stove model #FGF316ASB
Go to searspartdirect.com. Type in your COMPLETE model number and use the part locator illustrations on the following page. There should be a complete listing of part numbers for you to order on line. They should be listed under the "Backguard" heading as items number 32 and 36. Part numbers 316102303 and 316009009, respectively. I hope this helps you.
Aug 04, 2008 | Kitchen Ranges
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
105 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
