Question about Brother DCP-7020 All-In-One Laser Printer
The brother 5270 displays an error message "no paper" even when there is paper, what do i do?
5 Suggested Answers
  • 286 Answers
SOURCE: Even There are not papers inside the printer, at start I receive the message Paper Jam. In maintenence mode, the message is Error code 36. I tried to unplug few times, same thing. I don't know what to
Two possible causes.
1. There is paper jammed in the purge unit or on the left side of the machine. Move the print head by hand to the centre of travel and look inside at the ends of the head travel path. You might see paper jammed in there.
2. If there is no paper, you will have to take the machine apart and check the encoder strip on top of the head. It should fit into a slot on top of the head. If it is not in the slot, carefully reseat it into the slot, reassemble and test.
There are other more remote causes but those are the two common ones.
Posted on May 06, 2009
xptareq2000
  • 1447 Answers
SOURCE: The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Posted on Nov 22, 2009
GodBlessU
  • 3513 Answers
SOURCE: I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Posted on Jan 15, 2010
djgillstudio
  • 107 Answers
SOURCE: I have a Brother HL-4070CDW printer and the
hello, sorry to say that your machine will need the entire front door assembly, whats happening, is that the guide for paper feed, well it now has problem, so far the only way to fix it, is to replace this part, i have tried alot of temp. fixes, but only last a few days, and then it comes back, sometimes worse.
Posted on Oct 27, 2010
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
My printer Brother DCP 145C doesn't want to print. It takes the paper and then stops. It displays message: Print Unable 36.
Check for a paper jam. I just encountered this same error on my Brother MFC-290C, and that was the cause. I had to unplug the printer's power cable to clear the error message.
Sep 07, 2010 | Office Equipment & Supplies
Brother HC4040CN displays error message NO PAPER even though paper tray is full. Will not feed paper from Main tray.
The paper sensor flag above the paper tray on the printer chassis is either stuck or has broken of. You need to take the printer for repairs.
Aug 04, 2009 | Office Equipment & Supplies
"No Paper: error on Brother 8870DW
Hi ccswjk,
I have encountered this error before.
Printers have a sensor on the trays to detect the level of the paper in the tray. First try fanning the paper that you have in there. At time when the printer try to feed a paper and it has a hard time picking the paper up, it may display the no paper error message. Fanning makes the sheets of paper separate from each other making the paper pickup and feed process easier for the printer. And if there are adjustable levers around the paper in the tray, make sure they are snug around it. This helps the printer identify the paper size that's in the tray.
I hope that this solution I have provided you is as simple as what I have encountered. If not, the following link is the user's manual for the printer that you have. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002000/ALFB_UsaEngUsr_C.pdf
Page 19 contains the No error message troubleshooting, aside from what I already have provided above.
Mar 27, 2009 | Brother Multi-Function Center MFC-8870DW...
Have brother printer mfc8860dn. screen on printer says "no paper" even though tray full. it will not print regards sal b daidone
Hi pluries
Follow this link to the Brother site for a complete guide on how to clear the "no paper" error.
If the problem still persist the paper traysensors might be dirty and you will have to take it in to a service centre for a service. Please feel free to search the Repair Service Directory on this site for one close to you
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000000476&Sympt=How+do+I+clear+the++message+No+Paper++from+the+display%3f&Model=275&ProductGroup=5&ProductID=
Regards
Go-Tech
Dec 15, 2008 | Office Equipment & Supplies
Hl5270 clear "replace fuser" error
To reset any of the consumables on your HL-5270 you have to press "Go" and "+" at exactly the same time. You will be given an extended reset menu.
Nov 13, 2007 | Brother HL-5270DN Laser Printer
Brother Intellifax 2820 repair + automatic document feeder + sensor
Brother Error Codes
RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
B2 error = scanner or power supply error
Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken.
Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches
Nov 06, 2007 | Brother MFC-7220 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
