How to replace a Hitachi AX-M136i Optical Laser Head
My hitachi axm136i cd player keeps stopping play back for a few seconds every few tracks or so would this be the laser head at fault or something else ?
5 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: hitachi ax-m136u aerial outside
Hi What you probably need is a line transformer.
If you have 300 ohm "twin lead " from outside and the receiver has coax , you need a 300 to 75 ohm transformer.
If you have a coax coming in to 2 screw terminals on the receiver , you need a 75 ohm to 300 ohm transformer.
Some place like Radio Shack or a stereo store would have them.
Posted on Jan 22, 2009
SOURCE: re Hitachi AX-M80 - cD
This evening my daughter revealed she had the same problem. I wiped the eye with a tissue - now it works!
Some times the obvious is the answer.
Posted on Jun 16, 2009
dunnbiker
  • 8546 Answers
SOURCE: Hitachi AX-M 136i which is
Read before deciding...
http://www.repairfaq.org/sam/cdfaq.htm
The economics might point toward replacement or just buy an upgraded external Bluray and be one step closer to the future.
Posted on Feb 08, 2011
  • 1054 Answers
SOURCE: Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Posted on Jul 09, 2013
Jul 09, 2013 | Audio Players & Recorders
My sharp cd-ba200 will barley play cds
Put the player On for few hours or overnight. Now remove the panel and get access to the optical head unit, use a clean ear bud to polish the optical head. If not the optical head is weak and must be replaced.
Mar 14, 2012 | Sharp CD-BA200 CD Shelf System
My does my cdj keep skipping on track 1 and 2
Try a head cleaner first and if that doesnt work then look around for a new cd player or use the computer as if its what i think it is then its not reading correctly and it not really repairable ,Well financialy viable as i think the memory reading of the circuitry is questionable.
Dec 06, 2011 | Gemini Sound Products Gemini CDJ 203...
My DVD player won't read, keeps saying disk error
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jul 12, 2011 | Televison & Video
I have a dvd player built into my tv and until a few weeks ago worked fine. Now when I put a dvd in it tries reading it, i can hear it spin, then after a few minutes stops and says "incorrect...
Jul 11, 2011 | Sharp Televison & Video
Disc plays two seconds and then stops.
Clean it, if that does not fix it, then take the cover off and unplug the ribbon connector for the laser and re connect it while the unit is unplugged. If that does not clear it up then you can contact Sony for a software update if there is one available, If it still is acting up, spend your money on a new unit instead of repairing the old.
Jun 28, 2011 | Sony DVP-NS51P DVD Player
Need instructions/user guide for hitachi ax m136i please
Hi Rachel,
It's always better to refer to a manual for best use of your electronic devices,
Please find the download link of the manual below , you would need to fill some surveys and you will have the manual for free...:)
http://bit.ly/kJr8bD
Hope this helps ...:) Your feedback would be appreciated.
May 13, 2011 | Audio Players & Recorders
Skips when playing cd
In most cases when the CD does not play or is skipping it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Apr 15, 2011 | Audio Players & Recorders
Hitachi ax-m136u aerial outside
Jan 22, 2009 | Audio Players & Recorders
139 people viewed this question
 Grubhead
Grubhead
