Sherwood ax 3030r
Out put watts
  • 3,368 Answers
What is the question? More information is needed before somebody can help you. What type of watts are you asking, power input, output, music, RMS, etc.
Posted on Nov 04, 2014
2 Suggested Answers
  • 4234 Answers
SOURCE: Sherwood AX-7030R amp - doesn't switch on.
Something doesn't sound right. The standby circuit is usually very simple. The "regulator" is just a transistor. Can you request and post the parts that he/she can't find. I should be able to get you a source or substitutes.
Dan
Posted on Dec 17, 2008
Sherwood AX-4103 amp keeps clicking
Hello there.... Check your speaker wires and then if that doesn't do it? try replacing the fuses on the back of the amp.. make sure power is turned off and unplugged. If that doesn't work? Try one speaker at a time ... something is causing the system to short out. Hopefully it is not internally
Apr 21, 2014 | Sherwood Audio Players & Recorders
Sherwood ax 4050r
'Direct' disconnects the EQ normally. Don't trash your amp because of a noisy EQ when you can bypass it.
Mar 05, 2014 | Audio Players & Recorders
The main transformer in my Sherwood amplifier is down the primary winding is open circuit. I cannot find the transformer outputs as to replace it. does any one know the voltages and current ratings for...
I would contact Sherwood as Transformers are deemed to be safety components and should be replaced with excat parts or those recommended by the maker.
Jan 25, 2010 | Audio Players & Recorders
Sherwood AX-4050R Amp - faulty RCA inputs
It is rare for the actual input connectors to fail. More likely, either the solder connections need to be re-flowed, or the switching IC is defective. If you can solder, try resoldering the pins of the RCA connectors. Look closely at them and see if the PC board trace is broken. If the resoldering fails to resolve the problem, look for a switching IC with about 28 pins. It may be marked TC9163 or something similar. That will be the audio switching IC. I would change that next.
Dan
Nov 25, 2009 | Sherwood Audio Players & Recorders
Sherwood AX7030-R
I have a number of suppliers that can deliver internationally or are located in Europe. If you can list the part, I may be able to locate a few alternatives that might be more readily available as well.
Dan
Dec 17, 2008 | Sherwood RV-7050R Receiver
Dan
Dec 16, 2008 | Sherwood A-965 Amplifier
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
 Grubhead
Grubhead
