Question about Metabo Wep 14-150 Quickprotect Item Number: 600290420
Why does my grinder keep over heating - Metabo Wep 14-150 Quickprotect Item Number: 600290420
  • 682 Answers
Using it too hard? Or you used it too hard at one time, where smoke can out of it, now the insulation is burnt on the windings. In which case you may as well go shopping for a new one.
Posted on May 14, 2014
How to keep a motor frequent of the meat grinder?
If the motor on the grinder wasn't completely lubricated, you would have oil it frequently to keep the motor incorrect running condition. However, with a completely lubricated motor, there's no need for a way to worry about taking care of the grinder internally.Click the link for more details meat grinder reviews
Apr 11, 2018 | The Kitchen Appliances - Others
When i turn on the grinder the grinded coffee keeps going on.What should I do?
they usually keep grinding until the compartment with the grinded coffee gets full or until you turn off grinder. should turn off after compartment reaches full state.
Jun 25, 2016 | Mazzer Coffee-grinder SUPER JOLLY Electric
Repair Capresso CoffeeTEAM GS No heat Wont Pump Water
Check the elements. Unit heats water and forces that heated water out.
May 25, 2014 | Capresso CoffeeTEAM GS 10- cup Brewer and...
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
Saeco Primea Cappuccino must be reset I recive error mesage : error 1 I replaced grinder with a new one but the error message remained on screen and do not know how to reset
Hi,Ive just recieved an email saying that your having some problems with your machine. Its hard to keep up with all the error codes on the hundreds of machines on the market. Faulty grinder usually dont give an error code. The grinder will just not work if its faulty, which tells me theres a problem with grinder. If your showing an error 1, i'd be looking at the steam heating circuit. Faulty thermoblock, thermostat, solenoid, etc. Anyway, something has led you to replacing the grinder, so ill see if I can help. Some machines need to be told that it has been fixed, which is done through the programming. You know when you go in to the cleaning program, thats where it may have to be told. The grinder also has other electrical sensors which maybe at fault. On one of the wires that connect to the grinder is a little square thing that sits in a holder on the grinder. It maybe faulty.(not common fault that part). The machine will usually reset itself when you turn it off at the main toggel switch, and unplug it from the power point. When you turn the machine back on, it will do a self dianostic before it starts to heat. but as I said before, the grinder usually isn't part of the self dionostic on start up. If you turn it back on and error code comes back up, id be looking at thermoblocks or thermostats. If your still having troubles, give me more details on how the machines full operation is working. If the grinder is at fault, everything else should be working. Thanks Darryn
Oct 08, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
WHAT ARE THE MOST COMMON PROBLEMS WITH RIDGID GRINDERS?
Most common problems with small grinders in general (all brands) fall into two main catagories. Low power situation and lack of lubrication /debris or maintainance. Electric power tools are used with an extension cord. If too long of cord or improper gauge wire is used, the tool will heat up and burn the brushes, switch or copper winding (lower life of tool). If you feel the tool getting hot either let it cool or check power supply. Tools such as grinders generate lots of dust/debris that enters the tool. Abrasive dust entering tool prevents proper cooling and eats varnish off winding / wears carbon brushs and commutator. Grinders/polishers get packed inside with fluff coming off bonnets preventing cooling. All this overheating prevents grease from properly lubricating gears. Check gearcase for good lubrication and keep inside of the grinder clean. Good luck
Jul 13, 2011 | Ridgid 23983 Grinder 412" Angle
Hi - I have a miele cva5060 coffee machine. The grinder has stopped working, any ideas or solutions?
Sounds like grinder, over heated or got jammed by foriegn item (stone, pebble, etc...). If it over heated, then wait a few minutes, and then try again. Grinder also has a heat fuse that may have burnt out. If grinder doesn't work, after waiting 15 minutes, then a technician may have to replace grinder.
Nov 06, 2010 | Miele Coffee System
The grinder motor does not turn on when i start the coffee maker. how can i fix it?
Make sure you have the dial that sits on top of the filter basket turned to the open hole. Otherwise, it will not grind as it can not send the coffee grounds into the basket.
Nov 01, 2010 | Cuisinart DGB-300 Coffee Maker
Unit over heated
You will have to dismantle the burr chamber and clean out all the grounds, make sure the hole to the dosing chamber is clean also. Check the rectifier and filter assembly behind the motor to make sure nothing is burnt. Reassemble and test grinder.
May 03, 2009 | Gaggia MDF Medium Duty Coffee Grinder Wtih...
Heat
Hey Nashville,
I have a few suggestions/questions for you. I've had the Innova(Ascaso) Dream for several years now and use it at least twice daily. I would trust your own senses before sweating the gauges too much. If you're really worried about it being a temperature problem, my first question is whether or not the espresso is actually hot when it comes out.
But my best guess is honestly your beans and grinder (or lack thereof). The problem with using pre-ground beans is that even on the day you open the can, they won't be nearly as fresh as truly fresh ground beans you grind yourself. And the problem gets dramatically worse every day after they are opened.
The key to a thick, crema-laden espresso is very fresh beans that you grind right before making your espresso. You can certainly confirm that the machine is working with any old coffee grinder and a bag of *really* fresh beans from a local roaster.
You really need all the oils that come with really fresh-roasted and fresh-ground beans. And the beans really need to be ground very fine for espresso.
I keep a can of pre-ground Illy decaf beans around for the rare occasions I need to make a decaf, and it's like night a day between that and what I drink daily.
If you try the fresh beans and grind them yourself and can see the obvious difference, then you may want to invest in a good-quality burr grinder (as opposed to the spinning blade kind that most folks use for drip coffee). The reason is that with a burr grinder you can get consistently-sized particles every time. So once you get the setting right on your grinder you can keep pumping out the shots time after time. With a rotary blade grinder you get some big pieces, some little pieces and the water flows through too easily -- or you grind it longer and (1) burn the beans from the heat, and (2) end up with some particles that are just too small -- essentially dust, that will actually clog the process.
So, my best suggestion would be to find a local cafe/roaster and buy a half a pound of beans from them and grind yourself. If you don't have a grinder or want to eliminate a variable, ask them to grind it for you for an espresso machine.
Again, if you can see the difference (and I think you will), then you can consider getting yourself a good grinder.
Tony
Jan 03, 2009 | Ascaso Dream Espresso Machine
Metabo Wep 14-150 Quickprotect Item Number: 600290420 Logo
78 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
