Question about Electrolux Vacuums
Disassemble electrolux supercyclone motor - Electrolux Vacuums
2 Suggested Answers
  • 694 Answers
SOURCE: Disassemble electrolux olympia one vacuum.
Before taking the machine apart, always check for clogs in the hose and power nozzle, full bag, and/or plugged hole under the bag. Suction/vacuum loss can also be caused by leaky or cracked hose, including the section in the power nozzle.<br /> The best way to check for clogs is simply drop a large marble in one end and let it roll through. To check for leaks in hose, hook to exhaust port, pour a small amount of liquid dish soap in other end of hose, lift high and turn on vacuum. Bubbles will appear at badly worn spots and cracks in hose.<br /> There is no need to pull out the motor, as their is no filter surrounding it, motor does not need lubrication, and the above check should result in locating the problem.<br /> Repair manuals are only available to Electrolux franchise owners as highly restricted software.
Posted on Aug 22, 2010
Where do I get Electrolux motor in south Africa?
A local rewind or motor repair might prove more convenient and perhaps cheaper but Electrolux service is available in South Africa
Electrolux South Africa ' Home Appliances and Household Appliances
www.electrolux.co.za/
Welcome to Electrolux South Africa. Discover our range of ... Enter your postcode, town or city to find your nearest authorised dealer. Translation missing for ...
May 03, 2016 | Electrolux Vacuums
How do I reset Electrolux deepclean motor
not sure of you rmodel but I found this statement on one of them This vacuum includes a safety cut off power option if an object gets caught up in the deep clean nozzle, which can easily be reset by pressing a reset button located on the power nozzle.
Jan 31, 2015 | Electrolux Vacuums
Why does my 1521 overheats and turn off
Its probably full of dust and lint, and most likely has something wrapped around the motor shaft. Take it apart and inspect in and around the moving parts of the motor, impeller, shaft etc Best way if you are not too handy and poor memory. Either make a video of disassemble or detailed diagrams as you take it apart. It will make your life a lot easier when you re-assemble it!
Aug 30, 2014 | Electrolux Diamond Jubilee 1521 Vacuum...
How to take apart
www.doityourself.com/.../232396-electrolux-vacuum-disassembly.html
www.electrolux.com.au/Support/
Jul 13, 2014 | Electrolux Vacuums
Electrolux Z5935 Bagged Canister Vacuum disassemble
Anybody knows how to disassemble this unit ? I removed 4 screws but all seems to be still locked together. I tried to separate top from bottom and I can't.
Mar 30, 2013 | Electrolux Z5935 Bagged Canister Vacuum
How do I repair my Electrolux Lux 9000 cannister electrical cord retraction? It was pulled out as far as it would go and now it doesn't retract.
First, try standing vacuum on it's back end. Gently pull on cord and release. Try this a few times.
If this doesn't work, you'll need to take it to an authorized Aerus Electrolux store and let the service tech repair it. Although it's relatively easy to disassemble, reassembling correctly is trickier. I've had several machines come into the shop disassembled because the owner couldn't figure out how to put it together again.
Also, when taking the cord rewinder apart, there's a risk of breaking tabs that hold it together.
http://www.aerushome.com/storelocator/
Dec 19, 2010 | Electrolux Lux 5500 Canister Vacuum
I vacuumed a shirt. It came out immediately and there is now visible damage. The suction is working but the rotary piece with the brushes is not
Have you pressed the reset button on the power nozzle? If the power nozzle motor isn't running, this is the problem. If the PN motor is running, the problem is more likely to be a broken belt, and it needs replaced.
If the belt, I strongly recommend taking it to an authorized Aerus Electrolux dealer to have it replaced. It can be tricky disassembling and reassembling the PN without damaging something.
Nov 21, 2010 | Electrolux Guardian Bagged Canister Vacuum
Four nuts in rear housing, deep inside. Motor slides out after they are removed.
Jan 17, 2010 | Electrolux Vacuums
Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
Vacuums Logo
37 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
