Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
What causes water to leak out of Whirlpool refrigerator model GZ25FSRXYY0
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
iwillfixforu
  • 619 Answers
SOURCE: water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Posted on Feb 02, 2010
  • 2699 Answers
SOURCE: My whirlpool refrigerator is leaking water from
most likely you have a clogged drain,when the fridge goes into defrost it melts the ice off of the evap coil and it drains down to where the compressor is in the bottom section of the fridge,if the drain is plugged up the water will leak into the fridge section,take out all the food and shelves and remove the back wall of the freezer,if you know where the timer is or if it has a timer you can advance it and turn the heater on to help you out or unplug the unit so the fan isn't blowing or shut off the control,with a hair dryer melt all the ice,where ever you see styrofoam try not to leave the hair dryer in one place to long you can damage the styrofoam,the vents are under the fan,you can put a plate or something inside the fridge and pour hot water down the vents to melt out the ice if the vents have ice in them and it melts the ice faster and won't damage the styrofoam,now when you have the ice melted i use a steamer to clear the drain but if you don't have one you can use a turkey baster or a piece of hose and blow through it,anything you can think of to blow through the drain line,when you think you've cleared it pour hot water down the hole,if like a half a cupful goes down it's clear if it stays there it's not clear and you'll have to blow it out again,if you have any electrical wire with the ground wire in it you can use the copper wire wrap it on the heater or near it if it's a glass heater and when the heater comes on the wire will heat up and stop the drain from freezing in the future,stick it in the hole as far as it will go and leave a little extra so you can wrap it around the heater or like i said if you have a glass heater attach it to the metal frame as close to the heater as you can and you should be fine,they sell heater probes at the parts store also,let me know how you make out
Posted on Sep 07, 2010
bobicehouse
  • 1524 Answers
SOURCE: My whirlpool refrigerator 21TFA is leaking water
The drain is clogged. Remove freezer plate and pour a mixture of baking soda and warm water down drain.
Posted on Nov 02, 2010
heatman101
  • 43501 Answers
SOURCE: whirlpool top freezer model, leaking water into
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 07, 2011
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
Leaking water
Did you inspect if the hole in the drain inside the fridge at the bottom is not blocked? Try to clean it with a swab. Sometimes this causes a "leakage" of condensed water.
Dec 14, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
Does the refrigerator need to be level whirlpool if refrigerator leaks water inside fridge
It helps prevent water from freezing and blocking the defrost condensaate drain opening that causes water to flow over into other areas of your refrigerator. But being level will not stop this from happening on some refrigerators because they are simply prone to this problem happening. I will be here should you have other questions, Thanks Sea Breeze
Feb 01, 2013 | Whirlpool Refrigerators
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water freezes when going into ice maker model # ed25rfxfw01 whirlpool
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Mar 24, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have a whirlpool model GS6SHEXNQ00 that i purchased 3-1-2005. Recently I have been getting water in the bottom of the freezer. Could this be caused because the water chute may be frozen solid. (This is a...
Have you changed your filter for the water/ice? If, not this can be the problem. We recently had this issue with our Frigidaire we were leaking water under the veggie bin so badly even leaking on the floor until we finally changed out the filter for the ice/water machine. I hope this solves your problem.
Mar 01, 2018 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water is leaking from water dispenser
sound like the solinoids in the back oif your refrigerator may be leaking thru the valve causing the water the coutinue to come out and making a mess.
Feb 22, 2009 | Whirlpool GD2SHGX Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
135 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
