Question about Haier Washing Machines
Open stuck door lever not opening door - Haier Washing Machines
aborcass
  • 2651 Answers
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Posted on Feb 22, 2008
jonniewalker
  • 1031 Answers
SOURCE: Asko door latch stuck
The only way is to pull out the dishwasher ,unhook the latch and then unscrew the door panel.your dishwasher is installed with 2 screws to the underside of your countertop. its tricky but youll have to remove them adjust to leveling legs down this will give you more room to get some head bit in ther to remove the screws if its out then slide the d/w foward ,remove the strike plate door will open then you can get your dishes out first
Posted on Sep 20, 2008
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Posted on Dec 06, 2008
  • 10865 Answers
SOURCE: self-cleaning oven door won't open
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Posted on May 20, 2009
SOURCE: the gas tank door won't open with the lever, only if I put something under the lever after pulling it up I can pry open the door
More than likely the metal spring on the inside of the gas door is broken where the plastic attaches. Have someone hold the fuel door lever in the release position while you gently use a flat head screw drive to open the door. The part should cost you less than $10 at Toyota.
Posted on Aug 29, 2009
Garage door opener just hums, won't go up or down
Either the motor has seized or the door itself has jammed. Unlock the manual release (Usually a cord or lever hanging down 1/2 way along the track) Sometimes if its a side mounted motor, the lever will be at the side of the motor .Pull the cord or move the lever, and the door should be able to be opened manually. If its stuck then you will need to check the tracks and rollers on the door and door frames to see whats jamming it. Repair or replace as required. If the door comes up freely, that will prove its not the door jamming.Try leaving the door in the manual position and turn the motor on. The door wont open or close itself when in the manual position, but the motor should run. If it still hums, I would say the motor has seized. Sometimes, its cheaper to get a new opener / motor complete assembly rather than a replacement motor on its own. Check with the manufacturer and or supplier of the door opener to confirm.
Aug 26, 2014 | Building Materials
How do i manually retract - Exterior door stuck closed - removed knobs (levers)
PUT A SCREW DRIVER IN THE HOLE AND TURN IT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/joe_0ca6379e2eceb740
May 25, 2014 | Kwikset Lido Polished Brass Entry Lever...
F7 shows instead of door lock
This happens with a lot of ovens. It's because the mechanism that locks the door is stuck. When the door doesn't lock you can't do a self clean. They don't want you to be able to open the door while the oven is 800 degrees? or so. Look just below the little button that gets pushed in when the door is closed, upper left, and you should see a vertical slot. This is where a little lever comes out and grabs the slot on the door. There is a microswitch inside that tells the oven if the lever has come out or not. Your lever is stuck.
You can test this in a totally dangerous way by opening the door, holding in the button, and turning on the self cleaning. If everything is correct you will see the lever come out to grab and lock the door, but your's won't because it's stuck. Jiggle it or push on it or pull on it with needle nosed pliers. It frees up pretty easily. But when it does, the oven will go into self clean, which you don't want it to do with the door open, so turn it off, close the door and try again. It should work fine.
Dec 01, 2011 | Fisher and Paykel AeroTech OS302 Electric...
My passenger side door stoped opening from the outside. For one day i had to always open the door for passengers from my drivers seat. Now the inside wont open the door either. The outside handle is...
{: ) The passenger door trim panel should be removed, and the inside inspected carefully for any binding of linkages, stuck up levers or cables, or worn out grommets, broken pieces, before deciding for a doorlatch replacement.
Jun 03, 2011 | 2006 Chevrolet Trailblazer
Both door locks do not work properly. I can only open the drivers side door from the inside. And the passengers side door will not open at all. This is on a 1999 Ford Explorer Sport.
Do any of the door handles inside or out feel sloppy (when you pull on them does it feel like there is nothing connected to them)?
If so that the levers on the latches are probably rusted up and sticking. Say for example the outside door handle lever that is attached to the door latch is stuck half way in the open position it will not allow the door lock mechanism to lock or unlock. The door will still latch and stay closed because the lever will not be stuck far enough to release the latch mechanism from hold on to the striker.
I have had pretty good luck removing the door latch (the part that actually holds the door closed) and soaking in penetrating lube and working all the levers until they move freely.
As far as the door that doesn't open I suspect it is stuck in the lock position and one of the handle mechanisms is in the partial up position. Again the symptom would be a sloppy door handle. That lever will need to be put back in its normal resting position before the door can be unlocked. This can be done with a slim jim. Once you have the door panel apart on the door that still opens you will be able to see the parts you need to move. You can then use that knowledge to move those parts on the other door that doesn't open.
If you don't have any experience with a lockout kit (i suspect most people do not) that that's the best way I can describe how you can do this yourself.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 29, 2010 | 1999 Ford Explorer
Stuck rear door
I have the same problem with my 2003 I can't get the little door open that is behind the drivers side.
Jul 29, 2010 | 2002 Ford F150 Regular Cab
2001 nissan altima with a stuck gas cap door. Lever in front ''seems'' to be working. But mechanism is not releasing. Best way to manually open it.
Open the trunk and behind the trim cover near the gas door only on the inside there is a cable pull there also. the owners manual will show you where it is it you have it.
May 13, 2010 | 2001 Nissan Altima
I have a '04 rio and the driver side door is stuck shut, when the manual lock pin is pulled up, it snaps back down like its on a rubber band.
JEB, Homestead Florida
Total credit to rfbqwerty
Have 2003 Kia Rio 1.6, door shut, locking pin springs back down, I followed rfbqwerty istructions to the Penny and it worked in about 20 minutes I was able to open the door. The restst is a POC, thanks a million!!!
Option found in Google 6/16/2012
rfbqwerty
03-28-2006, 06:22 AM
Easy method to open a stuck Kia Rio door. Full credit to 'fastkia' for explaining how to open a stuck lock but after opening my lock by his method I found an easier way to do the job. You need a piece of straight wire (clothes hanger is good) and make a 3/4 inch square bend on one end. Wind down the window & push a tapered (plastic) wedge between the glass and the inside rubber to get a gap to work through. Poke the wire down beside the glass and pull up on the lever that is operated by the outside door handle. This is not the wire from the door handle but is the lever the wire connects to in the lock. While the lever is held up by your hook you can now pull up the locking button. Remove the wire from the door and everything works and it can be opened and closed as often as you like but don't press the button or use the key lock or it will be stuck again. The lever is normally held up by a small spring that has a sharp bend at one end and the spring will ALWAYS break at this bend. I used the same spring with a 'new' loop made from a section of paper clip to replace the old loop. Better than the original. No cost and it took less than 30 minutes
Mar 09, 2010 | 2002 Kia Rio
XG300 Fuel Door Stuck!
I THINK THERE IS A STRING IN THE TRUNK ON WICHEVER SIDE THE FUEL DOOR IS AT
Jan 30, 2009 | 2001 Hyundai XG300
Ice maker does not make ice and the in-door water is not working properly - it keeps running.
the water in the door problem after you fill up your cup with water it keeps running all over the floor.. it sounds like its a stuck contact on a micro switch inside the door compartment. that lever you are pushing your glass onto is atached to a little switch and if the contacts stay closed (like when a glass is pushing on it) the machine thinks "hey he still wants water". next time it does that try pushing on the spot you put the glass onto a couple of time to see if it stops the water. if so it most likely is the switch. to confirm that is the case you will have to open the plastic moulding from the fridge door to gain access to the switch.( always unplug any electricall device before openning to ensure your hair doesnt end up standing striaght up like a punk rocker) you will know which switch is the one you want to check by depressing the water lever on the front. Ohm check the switch for continuity to see if it gives you proper readings or it is in fact a bunk switch. it also could be a mechanical problem as the lever once unpressed is not opening the switch back up once the glass is removed but that is not as likely unless you are ramming the glass into the water dispensor
hope it helps
VeeDubb
Apr 23, 2008 | Refrigerators
Washing Machines Logo
12 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
