Question about Car Audio & Video
Sakyno Stereo Amplifier with no Sound problem. Open cover and found 3caps 50vlt/47uf, changed em again found A1941 transistor open changed and power up the Amp, look what i found just small sound coming up, can u help?
5 Suggested Answers
SOURCE: amplifier not working
i agree put in a repair shop or send it back to manufacturer
Posted on May 06, 2007
ampman
  • 98 Answers
SOURCE: No Audio From Amplifier
I would first check for "rail votage" at the rectifiers... If all of your audio transistors are not getting around 40 volts then check the transistors you replaced. They should be getting a 5 volt (10 volt square wave is checked with a scope) "drive" signal. If half of your power supply transistors are not getting a drive signal then replace the kia494/tl494/kia594/tl594---whatever it is. thats the ic chip that supplies the "drive" signal to the power supply transistors. Also follow the board closely out of the power supply transistor to the 494 chip.. there should be some small driver transistors in between.. make sure they are not shorted or fried as well... let me knoe if you need more help
Posted on Aug 18, 2007
  • 109 Answers
SOURCE: My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Posted on Jun 24, 2008
  • 631 Answers
SOURCE: Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 02, 2008
KONZERT AV-502A KARAOKE AMPLIFIER,POOR AUDIO,2-RESISTOR WORN OUT PLS. HELP ME
pls check burnt resistors, if ceramic it's value is .25 0hms 5 watts, if big carbon film resistor it's value is 10 ohms 3 watts. check also power transistors A1941 & C5198. also check driver transistor A940 & C2073
Jan 06, 2013 | Car Audio & Video
P61940 Sound but no picture
Could you gives us more info on how or from where you get the video source to your TV?
Jul 04, 2008 | RCA P46921 46" Rear Projection Television
Yamaha no power
you need to check the power supply input of your amplifier using a multimeter set your tester into a dc voltage reading.then measure the power input you must have a DC voltage supply reading..open the cover check the fuse an open fuse will turn the unit to no power.there are causes of blown fuse a shorted power transistor at the circuit will blown the fuse you need to replace faulty transistors before putting up a new fuse...check also the diode at the power supply section ,faulty diode could lead to the same problem..
Sep 30, 2011 | Yamaha P-2500 Amplifier
I have a fosgate 301x with power to the amp but none coming out
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure.
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Note:
I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit.
There are no internal fuses on any car audio Amplifier. Servicing will be required.
Dec 30, 2008 | Rockford Fosgate Punch 301X Car Audio...
Kenwood UD-551M hi-fi stereo ...problem
power problem of power amplifier .
if you can open the cover we can give try to solve this problem.
nuwan
Sep 02, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
My sound not working
is your receiver have power but no sound.the problem is in the power amplifier section ..the four transistor there is shorted or defected..change that transistor so it be better again..
Jul 03, 2008 | Audio Players & Recorders
Blown Channel on an amplifier
Look for low valued resistors that may look ok, but be open. Check the emitter resistors (.22 or .47 ohms). Check the transistors in the driver circuit as well.
Dan
Jun 06, 2008 | Denon AVR 3808Ci Receiver
Kenwood B-B5/B7 Power Amplifier/Graphic Equalizer
Change the Capacitor C110 (47FU 25v) I found this solution on another post somewhere and it has worked on mine too.
May 21, 2008 | Audio Players & Recorders
Jensen XA-J4090 Car Audio Amplifier
direct substitutes would be 2SC5198 and 2SA1941, you can pick them up from mcm electronics. or do a search on google for the part numbers to locate a supplier closer to home.
hope this helps,
trin
Oct 30, 2007 | Car Audio & Video
NAD C740 no longer reproducing music through loudspeakers
what was your amp? ic or transistorized? the output transistor of your amp may be opened, mostly it will short but because u still hear sound, maybe open and only the driver transistor are working. replacing output transistor or IC could solve the problem.
May 14, 2007 | NAD C320 2-Channel Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
