Question about Beko Washing Machines
Washing machine machine drum not spinning during wash cycle
  • 2 more comments
  • rajesh
    rajesh May 15, 2014
    put a load on, machine fills as it should but the drum doesn't turn round. I can hear the motor turning. other than the drum not moving the machine seems to run programme as normal
  • rajesh
    rajesh May 15, 2014
    I bought my machine just over a year ago (yes outside warrenty now!) and it had recently stopped working. Initially it began with a squeaking noise during a wash and stopped working. We looked at machine ourselves and found that the belt had simply slipped off. We put the belt back on, checked tension etc and ran an empty hot cycle to flush it all through.
  • rajesh
    rajesh May 19, 2014
    dear sir,
  • Sean Moore May 19, 2014
    Check and see if the motor is spinning if not you may have to replace it
    Problem Solver:
  • 37 Answers
Either the belt is broke or the direct drive motor is toast
Posted on May 14, 2014
Testimonial: "sir ,Belt is ok ,i checked.pls help me."
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
jumptrout51
  • 3361 Answers
SOURCE: Drum not spinning during some spin cycles
Replace the direct drive coupling.
Posted on Mar 23, 2009
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
BIKER T
  • 909 Answers
SOURCE: spin cycle is off balance washing machine is
i dont believe it is the agitator per say. Assuming this problem has just started and doesnt have transportation bolts still attatched. Two conditions cause the imballance. 1)(if unit is a top loader) Check if all 4 shock absorber springs are well lubricated and not sticking. 2)A more involved problem which often happens, Underneath the washer, is the drive motor. on the motor, is a round pulley. this pulley needs to come off and strip further until you see a long spring. If it is not broken, clean it up using a solvent and a rag. reassemble and test. (if spring is defective, it will slip instead of grip on a spin cycle.
Posted on Sep 17, 2009
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
During wash cycle it is only spinning one way
I hope you are referring to the agitator.
On washing machines, the drum only spins one way.
The agitator in the middle of the drum will spin both ways.
If your agitator only spins one way, something is broken.
Please share the year (?), make and model of the machine.
God bless your efforts.
Apr 12, 2016 | Washing Machines
Washer moves during spin cycle
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
May 27, 2012 | Westinghouse WWS833ES Super Capacity Top...
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Drum won't turn during wash cycle
If it has a condenser, then try a new one.
Nov 17, 2008 | Washing Machines
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
