Question about Brother Office Equipment & Supplies
What does "error 6D" means in a brother MFC-7360N?
    Champion:
  • Brother Expert
  • 265 Answers
Fuser unit error. (The center
thermistor detects 60 degrees or lower
temperature for 1 second during
ready state or printing.) , check your fuser .
Posted on May 15, 2014
  • 320 Answers
SOURCE: error 2001 on brother mfc 7420
please tell me more! i just checked my brother manual and i do not see a error code 2001????????????
Posted on Feb 16, 2009
  • 37 Answers
SOURCE: Machine Error 71, Brother MFC 8440
The problem is in the scanner motor.To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the keys.
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
I hope that this will cancel the error but if not canceled you should call the authorized serviceman to fix your machine.
Posted on Mar 01, 2009
SOURCE: machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
Posted on Apr 08, 2010
pineworks
  • 4041 Answers
SOURCE: brother mfc 685cw jammed then get error message
Hi can try this
Hi there
Brother 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Apr 25, 2010
  • 123 Answers
SOURCE: What does the error code
The problem is with the Fuser thermistor. The thermistor detects & heats the fuser temperatures. When this error comes up it means that the fuser thermister is not function corretly.
Unfortunatly it cant be reset so it will have to be replaced.
Good luck!!
Posted on Aug 02, 2010
How to repair head laser brother 7360
you do not repair them-- just replace
you can reset the error code if needed
Feb 16, 2015 | Brother MFC 7360N - Multifunction fax /...
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
My MFC-7360 says NO PAPER, but there is paper.
Most probabply will also say Please put paper in the MP tray ?
Sep 23, 2014 | Brother MFC 7360N - Multifunction fax /...
Reset brother toner counter mfC 7360N
If you are using refilled products then your re-manufacturer needs to reset the cartridge. For these there is a particular gear placement to allow the toner sensor to reset. If you are using Brother Original products then the brother helpdesk should talk you through this.
If you are filling your own cartridges well any issues you have with this reset process are at your own risk.
Once you have completed the reset process go to the brother website and download the latest firmware update for your machine as this will alleviate most of the issues with cartridges not being correctly set.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-style-parent:""; font-:10.0pt;"Times New Roman";}
  1. Open Front Cover.
  2. Display reads "Front Cover Open"
  3. Press the 'Clear' button
  4. Display reads "Replace Drum"
  5. DO NOT RESPOND TO THIS MESSAGE. Press '*, 0, 0' on the keypad.
  6. Press 'OK'
  7. Close Front Cover.
your machine should now be ready to print.
Aug 31, 2014 | Brother MFC 7360N - Multifunction fax /...
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Jul 01, 2014 | Brother MFC-9840CDW Laser Printer
Brother manual feed insert paper
I am a Brother employee working for the software technical support department.
We have a solution for your printing issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000016347
Description of Problem 100000012720
When I try to print from Microsoft Word or another program, I receive a message stating: Manual Feed, No Paper, or Load Paper XX. What can I do?
Brother Software Technical Support
Jun 29, 2014 | Brother MFC 7360N - Multifunction fax /...
Outlook won't print to Brother MFC7360N AllInOne Laser Printer
Must be set on Brother MFC-7360N series. Set on PC-FAX will not print with all programs, as it is printing with an output through the fax. Go to control panel, select devices, printers to change to pc-7360 series. This should print on all programs.
Mar 17, 2014 | Brother HL-5240 Laser Printer
Printer wont come out of sleep mode
Problem with your Patch Cable - Router or Switch. Last case...faulty Main PCB
Feb 27, 2014 | Brother mfc-7360n Mfc-7360n Monochrome...
Machine error 6D
I looked that error "6D" and could not find anything.
Although there is a error 6E that denotes a hardware problem with the machine.
Mar 12, 2010 | Brother MFC-8840D All-In-One Laser Printer
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
