Question about GE WJRR4170E Top Load Washer
Water only fills 1/2 way after putting in new switch
    President:
  • 1,185 Answers
What happens if you ask for a half load does it fill up to the top
If so you have wired the pressure switch up wrong and the machine thinks it is doing what it is told to do
I hope you wrote down the colors of the wires and which terminals they went on before you changed the unit ?
Posted on Jun 23, 2009
New Samsung Top Loader13kg WA13J571 Wobble Techn,used for the 1st time-water level 1(LOW)still filled the WHOLE machine with water.Bigger load on level5(FULL)never stopped filling with water.
use the features fuzzy logic, u only need to power on and start on the machine when u hve fill in the tub with cloths and soap. water will fill in according to the load filled.
Sep 08, 2017 | Samsung Washing Machines
WASHER WAS OVER FILLING PUT NEW PRESSURE SWITCH ON STILL OVER FILLING MANUALLY PUMPED WATER OUT MACHINE STOPS AND BEEPS 6 TIMES THEN 1 WHAT DOES THAT CODE MEAN
Can not tell you what the beeps mean because you did not tell us what model washer you have. Sounds like a problem with the water inlet valve sticking open.
Jun 20, 2015 | Washing Machines
Water level dont stop I bougth a new part and still have the same problem the water dont stop.
put the washer on cold,start to fill washer, turn washer off if water still keeps filling you have a bad water valve,do the same test on hot,if both turn off when you push stop then check the water level hose from the water level switch to the tub,if both ends are secure then replace the water level switch-mike
Feb 18, 2010 | Kenmore 22422 Top Load Washer
New whirlpool wtw5100VQ, will not fill hot/warm water,
Remove lid and just check connectors on rear of inlet vaulves are not earthing. Hope this helps. Also to check it is not a faulty solonoid remove wires from 1 terminal and tape them up, then put machine onto hot fill, if this does not blow trip switch then solinoid most likely at fault. Please ensure you disconnect power before touching wires. Good luck hope this helps
Feb 12, 2010 | Washing Machines
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
New install, used machine, need an old manual.
I'm too late for you but others could be helped. With the power off' make sure the timing cams are set to the beginning of cycle, Then push the cams with a finger untill the fill cam switch just activates. Then put the power on,close and latch door and water should enter the booster. You might have to do this 2 times to get water at correct level inside machine. When the cycle lite goes off check for water inside machine. If water level is too high, then take some water out with a cup.
Jan 19, 2010 | Moyer Diebel 401HT Dishwasher
2 problems 1st is the washer continues to fill with water when i put in a new load second is it wont spin
If the water keeps filling without cutting off, you either have a faulty inlet solenoide or your pressure hose and or pressure switch needs checking.
To isolate the acutal problem, start the machine on a new cycle. Change the water level to minimum or low before you start. Let the machine fill up. Keep checking the water intake as it fill up. Once the water level goes over the half way mark in your tank, if the machine starts its wash action then your pressure hose and switch are o.k. as they have signalled to the timer that the water level selected, has been reached.
However if the machine keeps filling up even though the wash action has started, then you have a faulty inlet solenoide/valve. Turn off water at the tap and get the valve replaced.
Ash
Oct 26, 2009 | General Electric WCSR2090G Top Load Washer
Maytag Washer Just Stopped After it Filled With Water (Timer?)
Cant rule out the timer but I suspect first check the lid switch. The timer and other components are fed from the lid switch on most models. Just put the2 wires together and reapply power if it works replace the lid switch. If not you'll have to have a wire diagram to know where to check next, but your water level switch "fill switch" could be at fault. it stops the water valve 1 way and can energize the rest of the circuits the other way. It may not be closing in the "full" direction. Again this switch if so wired will have 3 wires on it.
Mar 24, 2009 | Maytag Washing Machines
Water doesnt stop over fills the tub
Most washers have a pressure switch in the control panel that controls the water level. A plastic or rubber tube connects from the bottom of the tub to the pressure switch. The washer will fail to stop filling if the tube comes loose or develops a leak. The other possible problem is that the pressure switch is defective.
Mar 17, 2008 | Washing Machines
GE WJRR4170E Top Load Washer Logo
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
