Question about Canon Photography
My film camera comes out with half the picture missing
  • 29 Answers
The film hasn't loaded properly
Posted on Sep 18, 2014
  • 531 Answers
Shutter needs to be fixed
Posted on Jul 31, 2014
Area of film missing/not exposed
I had exactly the same accident and problem. Half the film did not print. The problem was the top roller. This in fact squeezes the developer evenly down the film as it moves up through and out of the camera. A plastic grommet holds each end of the roller bar in position. This ensures an even distribution of developer. One of the grommets had moved very very slightly out of position. I used a small screw driver to push it back into the correct position. The film now prints perfectly.
Jan 26, 2013 | FUJIFILM Instax 210 Film Camera
When taking a picture the film does not advance. It must be shut off and turned back on again. After developing those pictures, the top half of the picture is black indicating that the film is not...
if the film drive cogs are all ok then its the film advance drive gears on the motor drive striped or slipping,,you could test this by opening the camera and genteelly holding the film advance cogs with your finger and pressing the shutter if the film advance cogs stop turning then the drive gears are slipping or striped? this could be caused by the after load censer in the camera not censing the end of film roll and trying to get another frame out of it? like it read a 24ex as a 36ex but the censor faled to stop the motor drive winding on and that striped the gears
Aug 09, 2010 | Canon EOS Rebel K2 35mm SLR Camera
Hello, Please help me I love my camera! The last 3 rolls of film I have taken only the last half of the roll come out the first part of the film is black I'm only getting half of the pictures I take. It's...
Most likely this is a shutter problem. If you are using flash and getting the half pictures, then make sure the flash is a canon compatible flash and the synch is set to 60th. If the problem is all the time including non-flash pictures, then the shutter will have to be repaired.
Mar 26, 2010 | Canon EOS Rebel GII with 35-80 lens 35mm...
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
After develop the pictures i found that some images are completely blank and the images are cut into half. Half develop and half not. what the cause of it?? thanks
Might be film coming loose when inserting in loading spool and skipping when winding forward after making a shot. Could try bending first 1/2" of film tongue before inserting in slot in windup spool so that it won't slip out and be sure film sprocket holes are engaged with film transport sprockets and a bit under tension when loading film before closing camera cover. Your 'half-frame' problem might be that you are shooting at a 'flash' shutter setting of 1/60 when not using flash.
Oct 08, 2009 | Canon EOS 5000 35mm Film Camera
I can't get my Pentax Z50P film camera to automatically focus.
Remove the lens and clean the contacts between the body and the lens with a pencil eraser. Make sure the camera is on Autofocus mode. If these don't solve the problem, take it to an authorized service center.
Mar 03, 2009 | Pentax Photography
Weird film exposures
check the developed film if the sproket holes are intact.
check your camera without film.
(1) open the back, do it as if you were taking pictures with different apartures/shutter speeds. If you can see the light coming in from the lens (no matter how little or how fast), your shutter and aparture diaphram are good.
if not, send it for service.
(2) if yes, check that the winding sproket wheel turns when you advance film.
(3) if it goes freely, try it again with finger pressing the sproket wheel. if this stops the wheel to turn, it is the gear/shaft inside disengaged. send it for service, of course.
(4) if your camera has a button for multiple exposure, ensure that it can be turned on/off as you wish, or you do not pressed it unnoticed.
good luck
pc-cook
Jan 19, 2008 | Nikon N55 35mm SLR Camera
Nikon D-100 Camera
Hi observe the flashing maybe late or advance. try to picture in the day light without and with flash compare it.
Jan 01, 2008 | Olympus Camedia C-50 Zoom Digital Camera
Canon EOS Rebel G - The picture is cut in half
I'm afraid this is almost certainly a shutter fault - the second curtain of the focal-plane shutter is getting stuck half-way across the film and therefore not shutting properly. The fact that the other half of each frame is OK makes me think that the second curtain is not sticking totally but just moving very slowly for half of its run, thus seriously overexposing that half of the film. This is a repair shop job - unless you want to try it yourself: it may be just some dirt stuck in the track the shutter curtain runs in, but a fair bit of skill is needed to get to it & clean it without damaging anything!
Sep 29, 2007 | Canon EOS Rebel G 35mm SLR Camera
Panoramic pictures??
A panoramic photo on 35mm film is just cutting off the top and bottom. even if you can't set the camera that way, you can ask your local photo store to print any shot that way for you. Usually 2x the price of 4x6.
Sep 13, 2007 | Minolta Freedom Zoom 115 QD 35mm Point and...
Photography Logo
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
