Question about ASUS Computers & Internet
Bentley arnarge boddy kits - ASUS Computers & Internet
3 Suggested Answers
  • 136 Answers
SOURCE: HOW CAN I STOP ONE OF MY BENTLEY ARNARGE HEADIGHTS MISTING UP?
It is misting up because there is a leak in the housing somewhere. The solution would be to find the leak and sealing it with RTV. This would usually require removing the headlight assembly from the car to inspect it.
Posted on Aug 09, 2009
  • 1162 Answers
SOURCE: rear shocks
This the wrong place to ask that question.bet there is not 1 in 1 million on here that has one
Posted on Mar 30, 2014
Looking for the complete spare tires tools for Bentley Continental gt 2005
I saw a spare tire tool kit for your vehicle on ebay. A little over 500 bucks. That is a little pricey for me. You can take a look, see if that is what you need? I should have taken a snapshot, but, I didn't.
Nov 19, 2017 | Bentley Cars & Trucks
How do I change a pre-clutch kit on BMW E46
If you don't own one already, get a good manual. Robert Bentley offers the finest for many cars like yours. If a Bentley manual isn;t available, you will have to settle for a Haynes Manual. Chilton also makes them, but they aren't as thorough.
Apr 17, 2015 | BMW Cars & Trucks
Rear shocks
Mar 29, 2014 | 1999 Bentley Arnage
Shocks
On the hydro suspension system there are spheres which act as shock dampers. These are pumped up by the engine pump and run around 2400psi max.
As the wheels move up and down the 'ram' you would call the shock absorber displaces fluid into and out of the sphere/s. If these spheres are more than 6 years old, they go hard, because the nitrogen gas in them has leaked away. ( Gaseous Physics. They all do it. Nitrogen has a smaller molecual than the rubber trying to contain it.)
This nitrogen gas pushes a thick rubber diaphragm towards the hydraulic fluid acting as a spring. The small orifice the fluid has to pass through into and out of the sphere acts as a damper to the wheels movements up and down. A sensor on the axle/s keeps the pressure in the system at the correct ride hight.
You need new spheres if they have never been replaced.
I have a 99 bentley Arnarge, the shocks are not working properly. The car bounces constantly and when I had it checked, I was told the hydraullics were pumped all the way up and not adjusting! Any advice...
If just bouncy like riding in a wheel barrow, gas springs are the most likely fault.
If the rear is jacked up high then also look at the height control valve linkage in case it has become dislodged, damaged, moved. If not check the height control valve.
Rolls Royce Wales Bentley Wales
Bouns with hard ride
re arnarge hard ride you willreq 2 rear suspension spheres then bleed hydrolic suspension oil for this is rh5000
Sep 12, 2011 | 1999 Bentley Arnage
Most common maintenance problem for the bentely arnage.
They are many and all expensive...but it is a Bentley!
Oil seal behind flywheel leaks.
Fuel rail O rings leak fuel. Need to remove inter cooler and all that that involves....Bio fuel makes it happen sooner.
Vee belts wear..buy Danish made belts from dealer.
Power steering and alternator brackets subject to failure.
Radiator top outlet breaks off when top hose becomes old and stiff...radiator is $1300.00 plus $400.00 core charge and two way shipping.
Heavy car...tyre wear and suspension replacement common and often.
This is some of the repairs common to these Red Label Arnarge models.
If if a Green Label, then similar but more engine problems.
Feb 22, 2011 | 2003 Bentley Arnage
Need to reset service light on my 02 arnarge
same as a voltswagon procedure i think ,hold trip button in and turn ignition on and see what happens
Mar 07, 2010 | 2002 Bentley Arnage
Aug 09, 2009 | 2000 Bentley Arnage
Shocks
Remove the rear covers from the head light unit. Put these cover in the bin. After 2 days the head lights will be ok? I had this problem with my Arnage and it's never happened again. I have had this one now 3 years
Apr 08, 2009 | 1999 Bentley Arnage
Computers & Internet Logo
14 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
