Question about Panasonic DP-8020E Black and White Copier
Add paper problem while paper is already fed up in all tray
4 Suggested Answers
firecontrol7
  • 6696 Answers
SOURCE: Panasonic Workio 1810 - Tray 1 Add Paper Message
First why is the tray set for size A4 Paper. That is metric size paper for oversea locations. Should be set for 81/2"x11, or 11"x81/2.. is there any paper stuck behind the 1st tray? are the guides that hold the paper in place in the draw snug up aganist the paper in the draw. is the bottom sheet of paper in the stack/rem of paper benton the edge. All sheets of paper in the draw must be flat.
Posted on Jul 21, 2009
babaprithi
  • 372 Answers
SOURCE: i have problem on my
your interlock switch of the front door is not working. u have to remove the front cover and then short or replace the interlock switch.
Posted on Jul 02, 2011
babaprithi
  • 372 Answers
SOURCE: My panasonic Dp-8020P is giving
u have to short the front door interlock switch as it is not working.it happens in this model quite often.remove the front cover and door .the short the interlock switch with a wire .that's it ,if u can find one then better to replace it.
Posted on Aug 20, 2011
My Kodak printer wont grab the paper in the paper tray
Amandasplace:
There is a sensor that is located where the front edge of the paper sits when you load paper. If you take all of the paper out of the feed tray and use a flashlight to look in the throat of the paper feed area, you should see a small piece of plastic (in the shape of a blade) sticking up. If you do not see that sensor flag it may be broken off, or there may be a small piece of paper jammed against the sensor flag, keeping it from moving downward when you load the paper tray. That can happen if you pull a mis-fed piece of paper out of the machine in the opposite direction that the paper normally travels when printing. When you load the paper in the machine, it pushes that sensor flag down, telling the machine that there is paper loaded. either the sensor flag is broken off or there is something jamming the paper sensor, keeping it from being pushed down by the paper.
Nov 23, 2012 | Kodak ESP Office 2150 All-in-one Printer
How do i set it to print 11x17. It jams everytime and will not print to that size
Hello :-)
Please open the paper supply tray you wish to use. At the very front of the tray, to the right, you will see a blue dial. This dial is used to tell the copier what size paper it can expect to be fed. You can put many sizes of paper in the tray, but the blue dial MUST match the size that truly is in the tray. If ,for example, the blue dial is set at "LETTER" but the paper in the tray is 11x17, the copier will look at the dial setting and expect the paper to have passed its paper path sensors in a certain amount of time. So if the dial says 8.5x11 and the actual sheet of paper fed just keeps on moving by the sensors (11x17) the copier freaks and treats it as a paper jam assuming it has fed multiple sheets. Happy New Year to you and yours! :-)
Jan 19, 2011 | Canon ImageRunner 3025 Black and White...
Brother Laserjet 8860dn printer not picking up/feeding paper
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
To check, press the purple lever at the right front of the tray. The leading edge of the stack of paper in th etray should rise out of the tray so that the top piece of paper can be fed into the drum assembly. If the stack does not rise evenly, or will not rise, the rear adjustment is the problem.
You can inspect the springs in the paper tray by removing the plastic cover that is above the white translucent roller in the tray. To do this turn over the tray and release the catches with a little screwdriver. I do not think there is a missing spring. While you have the cover off clean the lnt from behind the roller.
Oct 01, 2009 | Brother MFC-8860DN All-In-One Laser...
No paper fed reload paper
The paper detect sensor could have dirt in it. Blow canned air directly on the sensor and try again. Asides from the sensor being bad the actuator for the sensor could be broken.
Sep 11, 2009 | Office Equipment & Supplies
HP PSC 1210xi does not accept paper from the paper tray.
Remove IE8. Use add / remove programs. It will put you back to IE7 and your printer problem will most likely be gone.
Aug 05, 2009 | HP Office Equipment & Supplies
Paper jam on a laserjet 4250
Is the paper tray set to the proper size? and are the tray guides snug against the paper?
Apr 14, 2009 | HP Office Equipment & Supplies
Keeps saying "paper out" when paper tray is full
Reduce the quantity of paper fed to the printer.
Mar 31, 2009 | Dell 922 All-In-One InkJet Printer
Can't seem to control which tray paper is fed from on my P1006
for windows: go to control panel - printers and faxes - in the printer configuration you need to set that letters are loaded in the main tray
Mar 21, 2009 | HP LaserJet 1022 Printer
My hp printer is telling me that i need to add
Not sure what printer you have but most consumer models don't actually detect paper in the tray. These machines will give an out of paper error if the paper is not picked up from the tray.
If the machine sounds like it is trying to pick up the paper but giving the error check and clean the pick up roller and look for something blocking the paper path.
hope this helps
Mar 15, 2009 | HP Office Equipment & Supplies
No paper fed
Pull the paper tray out, then turn the printer on it's side. There is a mechanisim that has some rubber band type grips that pick the paper up. Pull them off, turn them inside out and put them back on. Give it another try.
Jul 23, 2008 | Lexmark E234 Laser Printer
Panasonic DP-8020E Black and White Copier Logo
23 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
