Question about Motorola Mobility RAZR V3m Cellular Phone
I do not know how to set my clock on my razr after the time change last nite
Cannot find out how to reset clock on phone after time change
  • 33 more comments
  • Anonymous Nov 04, 2007
    how do you change the time on this thing
    Stupid Unicel..I checked my entire Cellphone and there is no way to change the Time settings.. I have the Razor V3 from the Company Motorola:..I don't understand why do they have to make in America only frustrating settings!
  • Anonymous Nov 05, 2007
    I am having the same problem!
  • sclark Nov 05, 2007
    I can not get clock to reset to/from daylight savings time. I have turned the phone off and turn it back on and it didn't update.
    cannot find out how to reset clock on phone after time change
  • kattt Nov 05, 2007
    i do not know how to set my clock after the time change
  • itsy Nov 05, 2007
    i pushed settings...then initial set up...the headings on my phone are as follows: speaker phone, auto PIN dial, auto redial, display time out, backlight, TTY, scroll, language, batter save, brightness, DTMF, hyphenation, master reset and master clear. there is NO setting for time and date...sigh
  • Anonymous Nov 06, 2007
    I have the same problem. I have two Razr's and one had the time correct itself automaticly and the other Razr is stuck in the wrong era
    maybe Verizon changes the options under initial set-up. Mine does not have the options shown in the solutions. I can't change my stupid clock either except under world clocks but it doesn't change my display.
  • jsph Nov 25, 2007
  • yillah Nov 28, 2007
    How to set date and time in motorola razr
  • deepearce Dec 12, 2007
    Same problem. Under Settings , initial setup, there is no time/date to change. HELP, I need an alarm tomorrow am to catch a plane.
  • jbrans3 Mar 06, 2008
    Cannot find any way to change date/time
  • Anonymous Mar 09, 2008
    same problem.
    time and date
    can not set time went thru all tools and setting no good
    Same problem...Help
    I have the Motorazr 2 cellphone and i dont know how to change the time.
    I simply shut down my phone all the way and re-started it and it fixed the time setting problem. I also could not manually re-set the time on my Mororola Razer, and after looking at all the solutions and finding none, I just shut it down and re-started it and Presto- it's set now!
  • Digggggger Mar 09, 2008
    reset clock after time change
    I have a krazer
    and I already looked
    up initial settings , BUT IT
    DOESNT HAVE TIME AND DATE
  • Anonymous Mar 10, 2008
    I am tryig to set my clock for daylight savings time
  • notebook Mar 10, 2008
    I tried the select Mexico as my time zone on the world clock setting.
  • rae1 Mar 23, 2008
    I am going to be in arizona for awhile i would like to change the time on my phone but i don't know how to do it.
  • Anonymous Jun 12, 2008
    i dont know how to change the time because it hav the wrong time
  • gsmblue69 Jun 13, 2008
    i dont know how to set the time and date after reinstalling a new battery
  • Anonymous Aug 17, 2008
    how can i reset a time here at my phone motorola v3?
  • sallen8806 Aug 28, 2008
    Can't reset the clock
  • Anonymous Nov 03, 2008
    This phone sucks. Can't figure out how to change the clock.
  • mlindenbusch Nov 13, 2008
    Glad I'm not the only one. How is this fixed!?
  • Anonymous Dec 06, 2008
    I have the same problem. Everyone tells me to look on the time and date setting and there isn't one.
  • Anonymous Mar 08, 2009
    same thing. cannot find anywhere to set "clock"
  • Anonymous Mar 09, 2009
    It must have happened last year when the clocks went back, but I can't figure out how to change it!
  • Anonymous Apr 04, 2009
    I just reset my phone becuase i can't get service anywhere i go but now i still don't have service, my phone thinks it January 1, 1980 and its 12:21!!! This sux!
  • Anonymous Apr 22, 2009
    i just want to know how can i change the time thats all it was from phillipines and i brought it here and time is 1:57PM while its 11:30 here in california
Settings
Initial Setup
Time and date
  • Turn AutoUpdate Off
select and make the change
Posted on Nov 05, 2007
Settings
Initial Setup
Time and date
I did this and it worked!
Menu
Settings
Initial Setup
Time and Date
Autoupdate: Off
Then you will be able to set the time manually.
Posted on Mar 09, 2009
I worked at this for over an hour and finally figured it out follow these steps and it will work !!!
-Go to settings
-Initial set up
-Go to DTMF It will say short , Long ,Off Click on Long it will change to the proper time !!!
Posted on Mar 08, 2009
Go back and read number 3!!!!!!!!!!!!!!!!!!!
Posted on Mar 14, 2010
There is a place under initial settings
set up
time and date ; then you arrow up or down to get hour , minute and a.m. or pm. then save and exit
time should be the first choice under set up
Posted on Jun 25, 2009
When you go to initial setup, you to to Time and Date. You have to turn autoupdate to OFF. Then you will get to the set time mode.
Posted on Nov 02, 2008
  • vip420 Jul 21, 2011
    This proved to be an excellent suggestion - I did just that and have managed to sort out the problem - thank you
It's here on the website:
http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/std_adp.php?p_faqid=1143&p_created=1171398429&p_sid=D8nn*s-i&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzYsMzYmcF9wcm9kcz0wJnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jbG9jaw**&p_li=&p_topview=1
Posted on Mar 11, 2008
I know how to change date and time. go on menu, then settings, then initial set-up, right at the top it says date and time ,click that then click the time if u want to change that or date if u wanna change that
Posted on Mar 31, 2008
    Problem Solver:
  • 18 Answers
Http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/GB-EN/MOTORAZR%20V3_.pdf
follow link
Posted on Dec 11, 2008
All you guys have to do is turn your phone off and leave it off for 30 seconds and it will change by itself and your good to go!
Posted on Mar 09, 2008
TOOLS THEN TO WORLD CLOCK. GO TO YOUR CITY. IF DST PUSH YES. TURN OFF AND IT WILL RESET. YOU NOW HAVE NEW UPDATED TIME..........curtislady_3
How do you change time from 24hr. to 12hr.
GO to clock settings.
turn autoupdate off.
exit menu
go back to clock settings.
select time format preference
exit menu
turn autoupdate back on.
May 07, 2011 | Motorola Mobility RAZR V3
How do I change time in the razon cell?
Your phone's time will be set from the network it is connected to.
If you need to change it to a specific time, Go to Menu > Settings & Tools > Tools > World Clock
Mar 14, 2011 | Motorola Mobility RAZR V3m Cellular Phone
I can't change the time back on my motorola razr i tried shutting it off for 30 seconds that didn't work, i tried going to settings and initial setup and there is no place that says date and time and there...
go to TOOLS, then WORLD CLOCK, then find the time zone you are in, then select SET DST at the bottom of the screen and that will set the time for you. hope this helped :)
Nov 07, 2010 | Motorola Mobility RAZR V3m Cellular Phone
I need to reset the time on my phone. Not quite sure how I do this. I can set the day, but not able to change the time.
Press "clock" and hold for a few seconds.It will say the day. If the day is wrong, use the arrow keys to move either forward or backword through the week. When the day is set press "clock" again and you will hear the hour. Press the arrow keys to move the hours. Press again for the minutes and use the arrow keys to set the minutes. Last press "clock" again and set AM or PM. By the way, the manual does not tell you how to set the clock.
Fame !
Jun 26, 2009 | Uniden Cordless Phone
Clock
If you meant that your previous Motorola had a clock and your current one does not have it on the display, its because your last phone's software was a different version. Only way to get your current Motorola to have the clock is to flash a newest software in there
Mar 10, 2009 | Motorola Mobility RAZR V3
Motorola Razor v3 clock setting problem dilema
Disable the "Automatic update" feature and set the clock manually.
To do this go to Menu, settings, initial setup, time and date, Autoupdate>Off, then set the clock and date.
May 01, 2008 | Motorola Mobility RAZR V3
Clock
Hi there, is the phone setup to automatically correlate its time to the your network provider? If it is, maybe the they need to adjust the time on their system:). Turning the auto time setting function off from handset settings menu should solve your problem.
regards
Graeme
Mar 12, 2008 | Motorola Mobility RAZR V3
Reset rasor clock
menu
settings
initial setup
time & date
Nov 25, 2007 | Motorola Mobility RAZR V3m Cellular Phone
My MOTOROLA V3 clock on my phone is on military time
settings, INITIAL SETUP, time and date, turn off auto update, change from 24 hr to am or pm.
Nov 18, 2007 | Motorola Mobility RAZR V3
Unable to change ringtone by accessing it through settings.
that was your last resort,, your program was corrupted... tnx man..do you know how to do it?
Jan 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
6,034 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
