Question about Baumatic Kitchen Ranges
The light and fan switch are stuck in rangehood how do youget them out
The light and fan switch are stuck in my baumatic BAH9002G rangehood how do i get them out
4 Suggested Answers
SOURCE: Change light bulbs in rangehood
I found the instruction manual on the Baumatic website.
Thanks anyway
Posted on Apr 19, 2009
SOURCE: Rangehood lights not working
I have a Fabyka Range Hood and know three other people who have had this exact problem (i.e both lights go out simulatneously but fan works fine). In my case I was able to pin it down to the transformer used by the halogen lights. This is an electronic transformer so it is less tolerant of power surges and such.
In the case of Fabyka the transformer is a black box connected to the inside of the hood with sticky tape with a black and white wire and two red wires. It is only used for the lights.
It is connected to the AC power via a black and white wire. you can disconnect this and us an LED power tester (about $2-$5 at most hardware stores) and see if you have power when you hit the switch.
In my case it is a 70W 120v to 12v halogen transformer. You can by a replacement off Amazon for about $12 including shipping or you can by a new one from Fabyka for about $30. I would suggest getting a slightly higher wattage transformer (I bought a 105watt for a dollar more).
You will need to disconnect the power before replacing but it is an easy fix.
1. Disconnect the AC power connector (black and white wires.)
2. The red wires coming out are the 12volt lines. If there is a connector, you can disconnect this, if not, you may need to cut these off.
3. Pull the tranformer off the back of the inside of the hood.
4. Cut the connectors off the old transformer. (Unless you buy Fabyka's.)
5. Connect them to the new transformer using wire connectors or crimps. (Make sure you connect black to black, white to white, and red to red.)
6. Make sure you have no exposed wires.
7. Connect to the corresponding connectors inside the hood. Connect the AC connector last.
8. Verify that the lights work properly.
9. Use sticky tape (or Gorilla tape) to attach the connector to the inside of the hood.
10. Enjoy the light.
Posted on Oct 02, 2011
  • 960 Answers
SOURCE: why baumatic rangehood BABT83.2AL stop working
Remove the filters and see if you can see the fan blade. Try turning the fan blade by hand. If its jammed up or tight, you may need a new motor. If it spins freely, turn on the rangehood and give the fan blade a spin . BE CAREFULL when doing this, if the motor starts up and runs properly after spinning it, it could be the start capacitor has failed. If it still wont run or if the fan is tight, you may need a new motor. Spare Parts should be available. You will have to trawl the internet looking for Baumatic parts suppliers in your area.
Posted on Jun 27, 2014
Testimonial: "thank you Steve, actually the fan started when i turned on the rangehood switch without I have to start it manually. But I don't think it is sucking as previously, very very weak, and when I change the no of fan to 1 (smallest) the fan stopped. When the no of fan to 6 (highest), the fan run but it's not strong. Appreciate any advise.. thanks again"
Why baumatic rangehood BABT83.2AL stop working
Jun 27, 2014 | Kitchen Ranges
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Mar 16, 2011 | Microwave Ovens
I want to clean the filters on my Baumatic Rangehood. I have removed them but can't find instructions about what to use eg very hot water? Warm? Detergent? etc
The metal filters can be cleaned with ANY good degreaser. The carbon filters need to be replaced. Parts are available from the manufacturer or an appliance repair shop that handles your brand.
May 02, 2010 | Baumatic Upright Freezer BV12A
Thanks anyway
Apr 18, 2009 | Kitchen Ranges
Rangehood malfunction
My Baumatic Rangehood model BAISL92.2 had the letter A flashing. I was advised by a repairman that it indicated the filters needed to be cleaned with warm soapy water. Apparently in my particular model there is a built in 30 hour timer for when the filters need to be cleaned. To remove the flashing letter A, I was advised to clean the filters, turn off the rangehood and while it was off, press the (-) (minus) button and hold for 5 seconds. It beeped and the flashing letter A was removed. This worked for my particular model - I couldn't guarantee it would be the solution for your model. I hope this is some help.
Jul 22, 2008 | Baumatic Upright Freezer BV12A
BABT83.2AL Canopy Rangehood The fan/suction is not working. A slight straining noise is heard. The light is working as is the display panel.
These units have a history of fan failure due to inferior 220 volt Italian fan.
I have just had fan fail and retrofitted a ebmpapst blower fan model D2E146HT6702 which is readily available in Aus for around $120.
The fan speed control is by inverter variable output so you don't use all the speed select wires that this fan has. Connect the Red wire on the range hood to the Black on the motor (High speed winding) and the Black on the range hood to the Blue on the motor (Neutral) and the earth to the earth (Green).
Disconnect and toss the cap in the white enclosure under the PC board enclosure (the new fan has the cap on board). Don't know how easy to fit in the range hood as mine is in an acoustic fan housing in the roof (makes it wisper quiet when running)
Apr 07, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Broan allure fan and light
Check that you have not accidentaly switched the wall socket off in the cupboard above the rangehood. The slide switch could also be faulty.
Oct 30, 2007 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
Light
easy. unscrew bulb cover then unscrew bulb. switch off at wall first.make sure you use a heat-proof bulb to replace
Apr 22, 2007 | Baumatic B180 Electric Single Oven
Kitchen Ranges Logo
83 people viewed this question
Top Baumatic Kitchen Ranges Experts
Greg Cann
Greg Cann
Treefrog15
Treefrog15
ray gallant
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
