Question about Car Audio & Video
Is rem a power wire on a hifonics car amp - Car Audio & Video
sparky1500
  • 1066 Answers
SOURCE: REM input on Car power amps
you should connect it to the 12v positive of the power supply, maybe install a switch in line between the amp and power supply.
Posted on May 17, 2008
  • 108 Answers
SOURCE: hifonics gemini series vii car amp/ lost wiring instructions
Output Power at 11.5V to 16V (20Hz - 20KHz):
4 x 50W @ 4 ohms (0.02% THD)
4 x 70W @ 2 ohms (0.15% THD)
2 x 140W @ 4 ohms bridged
Damping Factor: 150 (20Hz - 200Hz)
Fuse: 30A (4 ohms)
Dimensions: 11.42" x 8.7" x 2.45" (29cm x 22cm x 6.2cm)
Weight: 7.5 lb. (3.4 kg.)
Here is a link to your product's pdf file for instruction manual:
http://www.maxxsonics.net/manuals/hifonics/pdfs/hf_SERIESVII.pdf
Posted on Aug 10, 2008
  • 631 Answers
SOURCE: Hifonics gemini series vii car amp
There's a diagram at the bottom of the following page:
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
Let me know if you have any other questions.
Posted on Sep 18, 2008
flexion1
  • 737 Answers
SOURCE: after connecting my Sony XM-1252GTR Car Audio Amplifier it won't turn on
Hi. You should be able to turn the amp on by touching the remote wire to the B+ main power terminal. this will tell you if it is a problem with the remote from your head unit.
Mark
Posted on Oct 25, 2008
  • 4 Answers
SOURCE: 3 amps 2 subs sound system for car, need wiring help
it is easy to hook it up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jan 14, 2009
I have a brand new Hifonics amp 1500 watt Brutus the only thing that powers up is the logo the power light and protection light stay off the amp brand new out the box what can be the problem
Some amps will not power up internally if u donot have remote wire. Also if u connect power then remote wire it will not power up until u reconnect in correct order. But if all that is ok. Than u have a bad amp
Mar 11, 2017 | Hifonics Car Audio & Video
Not getting power when ignition is on and what is the rem imput for
the rem input (probably a blue wire) is what tells your amp to come on. the power supply is the red wire, that means that the amp is powered. it is not 'on' until the remote (rem) wire is powered. It acts like a power button or switch that is controlled by your unit. there are ways around conventional wiring if you have trouble getting your unit out.
Jan 29, 2011 | Fusion FEW12PK Car Subwoofer
!!!red protect light is on!!!
Hello beaugarcia26,
Unless the amp itself is defective, there's a short or ground somewhere.
First disconnect the speaker wires and RCA (or high level) inputs, leaving just ground, remote turn-on and power leads connected. Then see if the amp powers up normally. If it doesn't check the ground with a multimeter and make sure it is good. If the amp powers up normally, check the speaker, speaker wires and inputs for shorts or grounds.
Hope this helps.
Sep 02, 2009 | Hifonics Brutus BX 1205D Car Audio...
Pyle pla2170
The power cable and the rem cable need to have different power sources. The best thing to hook the rem. to is a power antenna wire, or if you don't have a power antenna, you'd need to hook it to the ign. or accessory wire.
Jul 31, 2009 | Pyle PLA2180 Car Audio Amplifier
Bxi 1606d amp it turns on power up but no sound
Well i sounds like your amp is shot. Or you have the subs wired incorrectly to the amp. Each amp is different in stability with ohm loads and each amp performs differently at each load. Sounds like it was wired at the wrong ohm load in the past or it came defective from factory. Definately send it back if u just got it.
Jun 09, 2009 | Hifonics BXI 1606D Car Audio Amplifier
No power to amp
you need to hook up the rem wire, that runs from head unit to amp its usaully a blue wire on the head unit and there should be a rem input near where the power leads are on the amp
Mar 21, 2009 | Kicker ZX400.1 Car Audio Amplifier
Amp shuts off when switched from radio to cd
your amps rem wire is hooked to the power antenna wire on your head unit and so when you turn off the radio you would nolonger need an antenna so it powers down and would lower the antenna.Depending on the head unit you should have one output for the power antenna and one for the amp rem......If your head unit doesn't have the rem output you can wire it to the switched wire that powers your head unit but keep in mind the amp will stay on while you have the key in acc or run position even if your head unit is off.
hope this helps!
Jan 16, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Powers isnt turning on but everythings hooked up?
Check the fuses. If the fuse is bad the amp's power supply is burnt. If the red light stays red and never goes green then your amp is in protect mode and the output section is burnt.To test for rem. problem just use a jumper wire (paper clip... or whatever)to jump from +12v power to rem. If rem. wire has no voltage when your radio is turned on that will make your amp come on. then look for the fuse in the rem. line. Good luck !
barneyluc
Oct 03, 2008 | Car Audio & Video
As i read your problem i can recommend you that connecting each of the hifonics amp to each hifonics sub with the same specs by getting the specs in interfacing the two or you can simply look to the output of the amp and the input of the sub and find a suitable plug that fits to them.
In the case if you want to run each hamp to individually run each sub but sharing 3 farad capacitor: what i can suggest is that you connect in parallel one connecting wire of each input or ouput of the amp or sub. Its like connecting a connector from each of the input or output of the amp or sub to one leg of the capacitor, and connecting two wires to the other leg, one is being connected to the amp or sub and the other wire is connected to the other amp or sub.
In the case of putting a circuit breaker at the car battery: what i can suggest is that you find an appropriate circuit breaker that fits the specs of the car battery then connect it in series on the positive supply or read the specs of the circuit breaker before you connect it to the battery. Having a circuit breaker is like having a fuse but with special advantages in favor of the circuit breaker.
In the case of having power to the amps you can run one power wire to the amps by dividing the power wire into two, one connected to the amp and the other wire to the other amp. Then you can connect each amp and sub in series individually by connecting one wire b/w amp and sub. I hope i solved your problem
Feb 08, 2008 | Car Audio & Video
Amp does not work
make sure your power and ground wires are 4 gauge thats a big power puller also make sure your wires to woofers are correct!and you want a short ground wire and a good spot for it no paint!!
if there out of phase that will shut it off BUT you might be needing a battery cap. MORE POWER!!!!they dont cost much
and save your battery and alt.hifonics is a good choice my favorite are the series 7 they dont make them like that anymore!
hope this helps one more thing your alt.how many amps is it?
my honda is only 60 amps your brutus pulls that all day !
(BATT.CAP.or HAVE ALT.WRAPED for more power.
Dec 01, 2007 | Hifonics Brutus BX 1505D Car Audio...
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
