Question about Garden
Gardentec CAN YOU GET A FUEL CAP FOR GARDENTEC CHAINSAW 52CC articleNo542076
    Genius:
  • 1,114 Answers
http://www.gardentec.cn/upload/170-1.jpg
info@winplus-intl.com
I suggest you contact the above and ask where you can purchase the part,
Posted on May 14, 2014
2 Suggested Answers
j_penny
SOURCE: I have a Gardentec 38
either chain has come off drive sprocket or clutch is knacked, --adjust chain to reset it on sprocket by loosening the two flange nuts on the blade bar side, or check clutc and or brake band is not stuck on
Posted on Nov 08, 2012
How do I change the spool on my gardentec strimmer
www.gardentec.cn/products.asp
Get a operating manual to find out how.
May 24, 2014 | Garden
The recoil starter assembly has shattered on my gardentec chainsaw. can I purchase a new assembly?
I'm not familiar with the model 'Gardentec' is it a Ryobi product?
In many cases now and especially on cheaper hobby saws the starter pawls are not available as individual items. However I'll explain the process of replacement.
Firstly, remove the starter housing and the plastic shield fitted to most saws between the starter pulley and flywheel. You will now have to remove the flywheel. The centre nut is a normal R/H thread but you will have to lock the piston first.
Remove the sparkplug and if a piston lock tool is not available then a length of starter rope will suffice, Turn the engine over by hand until the piston is opposite top dead centre (furtherest from sight) then push as much of the starter rope into the hole as you can. This will stop the crankshaft from turning when you undo the flywheel nut. Once the nut is undone your next step will be to remove the flywheel and they seldom slip off easily. In many cases a puller will be required but use caution or the flywheel will shatter. Do not hit the flywheel with a hammer or damage will occur. Light pressure can be applied at opposite sides of the flywheel by inserting two screwdrivers and lightly levering. Do not use too great a force.
If these process fail to produce results then you should seek the help of a chainsaw service shop.
Now once the flywheel has been removed you can turn it over and insert a pin punch to drift out the pawl pivot pins.
Reassembly is a lot easier.
Mar 22, 2014 | Garden
I have a gardentec 52cc chainsaw which wont start. I have a spark and fuel getting thro.
Hi you mentioned that you defo getting spark is that from spark plug against side of engine, try this put a very small amount 50/50 pet oil inside cylinder head through sparky entrance screw spark plug back in try it now if it pops abit no matter after 5 times you have a carb prob float faulty jets blocked, blocked feed line, Advise you need a bowl petrol no smoking wash carb in it blow clean jets put back only when all is clean check petrol tube sometimes they go hard and block up make sure petrol is getting to cylinder head, hopes this helps
Feb 17, 2014 | Garden
Pull start spool gardentec worn prematurely.
if it's an off brand saw then who knows... I have never even heard of the brand
as for parts I hope you saved your manual
Oct 18, 2013 | Garden
Where can i get gardentec chainsaw parts
GHS Limited have spares for all chinese chainsaws!
Nov 08, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Gas leaks out when chainsaw is tilted and in use
sounds like you have a cracked fuel tank or stripped out gas cap
Apr 13, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Gardentec fly wheel pully springs
They can be found on Ebay. I have bought many parts for Huskys and other brands there. If not, try Amazon.
Mar 17, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have a gardentec 38cc petrol chainsaw which wont start
What kind of saw. How old? New Spark Plug? How old is the gas inside it? Is the air filter dirty? When you try to start it does it turn easy or is it a little stubborn or won't turn at all?
Mar 29, 2011 | Garden
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
