Palsonic PDP4226HD The power button and remote control will not turn the TV on. The remote has fresh batteries. The red stand-by button is not on and was not on when i first tried to turn it on earlier. Why can't i turn it on?
  • 346 Answers
SOURCE: Code for Palsonic 6830TG TV
if the volume down ts working then that means the remote is working if the volume + does not work and the channel + then they need to be cleaned with isopropyl alcohol using a cotton swab, that means you will have to open up the remote control
Posted on May 28, 2008
  • 1214 Answers
SOURCE: i have a brand new
You may need to recode the remote since you changed batteries, and the newly installed batteries are new, and installed correctly.
Posted on Jan 29, 2009
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
SOURCE: The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
Posted on Sep 28, 2009
SOURCE: I have a 19" Genesis LCD TV and I need the Remote Control Code
I have a 22" genesis LCD and can not get my Direct tv remote to work?
Posted on Nov 14, 2009
Red light on but wont turn on palsonic tftv4932led
sorry about your issue but the Tv you have is generic low grade and not even worth 100 to replace all over the internet
I suggest you go buy a new TV because the one u have is not worth paying anybody to fix
Feb 12, 2018 | Televison & Video
Palsonic 32" model TFTV326FHD, remote sensor light just keeps flashing red when you try to turn on TV with remote. We tried new batteries, unplugging TV, other connections fine, but TV wont switch on.
The "remote sensor light" is the power indicator and it is blinking to let you know either an internal fuse is open or the power supply has failed.
Jan 16, 2018 | Televison & Video
My palsonic tv remote wont work even with new batteries:(
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
https://youtu.be/wUpnETSm6_k
Sep 12, 2016 | Televison & Video
I have a palsonic model no: TFTV492LED and I can't change it off AV1. I want to put it on HDMI I have no remote either.
Try the front panel button labeled Source; it's the second button from the left. (The first button is the Power button.) All of the buttons are on the right hand side of the bottom frame of the TV. Use the Channel Up/Down arrows to navigate through the list of inputs. Try waiting for the selection to take effect. (The documentation says press OK or the Volume Up button. Sometimes, the Source button on the TV functions as an OK button. This isn't clearly identified for the Palsonic.)
If the HDMI input is greyed out, the TV may not be seeing a compatible signal from the source. Try turning on the device when the TV is off, then turn on the TV. I'm not sure if this TV will correctly see the signal from a computer. However, on some laptops, you'll need to enable the external video first. This is disabled to save power. Then turn off the computer. Finally, turn on the TV before turning the computer back on.
Palsonic has the manual available for the TFTV492LED on the product (discontinued) site under the Downloads tab. See http://palsonic.com.au/archive/led-tv/tftv492led.htm . The direct link to the manual is http://palsonic.com.au/customer_service/led-instruct/Palsonic_TFTV492LED_Manual.pdf .
I hope this helps.
Feb 29, 2016 | Televison & Video
The TV comes on but it just says stand by and does nothing else
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Jan 02, 2016 | Televison & Video
My sanyoRC-S071 remote only works some times
This could be batteries that need to be replaced (try again but standing closer to the TV to see if it works all the time), failing to aim the remote at the TV, obstructions (dirt / dust) on the remote IR transmit window or TV IR receive window.
Mar 24, 2015 | Televison & Video
Am trying to reset my panasonic TV using the RM V310 I was shown to press the SET button then the POWER button and release ....then the TV button ...then the +Ch and the POWER button back an forth until...
he remote control shluld be checked for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Dec 03, 2014 | Televison & Video
The remote will not turn the TV on. When I turn it on with the button on the front, the power light on the TV starts blinking (no sound or picture). The red light will blink forever, and the TV will n
Nov 01, 2014 | Toshiba Televison & Video
BOUGHT A USED SHARP TV WITH THE POWER BUTTON MISSING .IT USED TO COME ON WITH REMOTE BUT EVEN WITH FRESH BATTERIES IN THE REMOTE IT WILL NOT TURN ON THE TV. DO YOU THINK THE REMOTE WENT BAD?
To power on the tv with your remote, the tv must be in stand-by. You should look if the tv is in stand by. If it is not, you should use a pen to power on the tv. (press where the button was)
hope it helps :)
Apr 22, 2010 | Sharp 25R-S100 25" TV
Codes for palsonic televisions
Hi, that TV is not listed in the code list for your model.. You can try an automatic search by doing the following:
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. The
remote control is in programming mode
3. Press and release power. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
4. Press CHANNEL + or CHANNEL - repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
If the device responds, the remote control has been
programmed. If the device does not respond, repeat steps 2-5.
For future needs, here is the link to your manual:
Bookstone 538744 remote manual
Apr 12, 2008 | Brookstone 538744 Remote Control
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
