Question about GPS
V2.0ABF-UI20-SD-AR JEVA - GPS
How to connect my Jeva GPS to mu PC for Updates
My GPS connects to the computer using the USB port. Cords or available at the electronics department of any discount store.
Go to their website, turn the device on and it should be found for the update.
May 15, 2014 | GPS
My ar dsi is not being picked up by the computer,usb driver says not able to install what should i do
OK I figured the solution to this problom, Well All You Have To Do Is Have A Micro SD CARD And a DSi!
1. Plug Your Micro SD card Into Your AR ds/Dsi
2.Plug Your Ar Ds/Dsi Into Your Ds/DSi Warning: Do Not Turn On your Ds/Dsi
3. While Keeping Your AR DS/Dsi Inside your system Get your wire and plug it into your ar and Your Computer
4. Open Ar manager and It will work
Sep 29, 2010 | Datel Action Replay for Nintendo DS
Dvd's aren't fitting my screen, the sides and top/bottom is being cut of. I've tried the display menu, zoom, and making it widescreen, and it doesn't work.
Are you playing wide-screen movies on a 4x3=1.33:1 (standard=SD) TV? DVD output by default is SD. Even 16x9=1.78:1 (HD) movies with have top and bottom bars. Many "wide-screen" DVDs are squeezed horizontally so that you have to stretch them. Many theatrical releases are up to 2.7:1 or so. Side bars indicate you have the DVD output set for 4x3 and your TV is HD-like. There are usually controls for the screen format on HD TVs--no controls on SD TV. Hey, early movies were 1:1--take them side bars. More on aspect ratio (AR) in Wiki, I bet. With letterbox of SD you can get "pillar box" with black on all 4 side. Get a better source and/or choose a different AR. -Ken
Jul 15, 2009 | Pioneer DV-400V DVD Player
On a sharp arm 257 can you a drum unit or just blade and drum
Did you mean drum frame unit ? This frame include all the spare parts of drum unit except drum and drum fixing plate. The code number is AR 310 DU ( DRUM FRAME UNIT ).
DRUM : AR 310 DR
CL. BLADE : AR 271 AK
DEVELOPER : AR 271 SD
Jun 03, 2009 | Sharp AR-M237 Copier
GPS Logo
24 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
