Question about Stihl Trimmer Throttle Cable Km 40 50 56 70
How do you replace throttle cable on an fs 44 weed eater
3 Suggested Answers
  • 457 Answers
SOURCE: My Stihl FS 85 Weed Eater gets no fire to the spark plug
older models have a pick up and condenser for spark. newer models have pick up and ignition module. the pick up rust the condensers and modules go bad. first take apart to expose flywheel then ck for rust on flywheel at pick up if rusty clean set pick up clearance to that of a matchbook or ten thousands of a inch.if still no spark change condenser or module.
Posted on Jul 14, 2012
  • 3519 Answers
SOURCE: How much would I charge to replace the throttle cable on a stihl pro fs 85 weed eater
Hi Bruce:
If it were me, I'd get the owner to pay for the part and I'd do it for free. but then I'm retired and always like a project to help with.
I'd suggest that you would charge what you think your time is worth, and if it is more than a shop would charge, probably best just to let them repair it.
Posted on Jun 15, 2016
Hi Bruce:
Jun 15, 2016 | Stihl Garden
Stihl fs 85 weed eater trigger replacement
Take a look...
This may give you a little guidance?
also check here for all things Stihl...
Stihl Trimmer Throttle Outdoor Power Equipment
And this video...
And you may find this useful...
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/FS80_85_Manual.pdf
Jun 10, 2015 | Stihl FS 85 Weed Eater
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    What is the air n fuel mixture for a stihl FS 44 weed eater
    50:1 ratio on all stihl products... If that helps
    Aug 08, 2013 | Stihl Garden
    THE FS 46C WEEDEATER WILL IDLE JUST FINE, BUT WILL NOT REV UP WHEN PULLING ON THE TRIGGER. THE THROTTLE CABLE IS NOT DISCONNECTED AND THE CARB IS CLEAN. ANY SUGGESTIONS?
    easy... if the carb adjustments are still factory set the you just need to replace the muffler screen or also called a spark arrester.it covers the muffler exit....
    Sep 13, 2012 | Stihl FS 85 Weed Eater
    I need to see how to replace the throddle cable assembly on a stihl fs 75
    Here is a link to the parts manual, there ate a few different types of throttle setup.
    Oct 05, 2011 | Stihl FS 85 Weed Eater
    How do i change the cord on a FS 86 weed eater?
    most weed eaters have caseings and you just unscrew and take off and you will plainly see how to replace the cord
    Jun 24, 2009 | Garden
    Stihl Trimmer Throttle Cable Km 40 50 56 70 Logo
    146 people viewed this question
    Top Stihl Garden Experts
    Joseph Mueller
    Joseph Mueller
    brotherscott
    Level 1 Expert
    ray gallant
    Are you a Stihl Garden Expert? Answer questions, earn points and help others
