Question about JBL LSR2325P Powered Studio Monitor
How do I disassemble a JBL LSR2325P to replace the woofer?
Ordered a new woofer for this guy as mine had begun to tear around the foam padding, but not sure how to get safely inside to do the swap.
  • JBL Master
  • 3,769 Answers
Manufacturers of commercially built speaker enclosures don't usually take chances, especially with the infinite baffle variety, and so tend to glue everything together to prevent resonances and vibrations. Zillions of screws and gaskets would be too expensive.
The back is usually the point of access but it might be the front. Sometimes the screws securing a drive unit can be accessed and with lots of luck the drive unit can be released and lowered into the cabinet which will allow access to the inside of the back panel so with the aid of a piece of wood and a large hammer...
Failing that it will be a matter of using guile and a moderate amount of brute force even though it could mean repairing or replacing the panel.
Posted on Mar 24, 2015
Did you ever figure out how to get into this enclosure? I am having the same issue now.
Subwoofer output distorted
Check to see if the speaker foam surrounds have disintegrated on your subwoofer. I bet it is. If so the speaker will sound like it is distorting or vibrating. Electrically it should be fine. My 2000 Avalon has this same problem with the 8" JBL subwoofer. It is a common problem and an easy fix. Go online to ebay or Amazon and purchase a speaker foam surround replacement kit (Ranges from $18.00 to $25). Youtube also has "How To" videos on how to repair this on your own. I just ordered my foam kit and awaiting the parts. Here is one for $23 but you can shop around for other deals.
Toyota JBL Speaker Foam Edge Repair Replacement Kit 86160 AC180 Avalon...
Feb 24, 2014 | 2005 Toyota Avalon
Remote reset
Yes the woofer and tweeter can be replaced but the woofer needs a recone kit to repair as the whole speaker cannot be replaced without replacing half of the speaker enclosure.... call JBL pro or a service center for help.
Oct 08, 2013 | JBL EON15 G2 Main / Stereo Speaker
JBL speaker's woofer occasionally cuts out - tweeter still works.
Your driver has a damaged voice coil, you can either find a speaker repairer to replace the voice coil or find a replacement driver to fit.
Mar 05, 2012 | JBL Northridge Package System
REPAIR CONE TEAR IN 18"
If the tear is large, or the speaker cone is brittle because of age, you might be best off having the speaker completely reconed. There are companies that offer the service, or you can buy replacement cones and do it yourself.
For small tears (an inch or so long), you can glue a patch in place. I have used a piece of a paper coffee filter as a patch, and plain white Elmer's glue slightly thinned with water. Put the patch over the tear and use a small brush to spread a thin layer of glue over it. Give it a day to thoroughly dry and you should be set.
I have found this repair to be more effective on smaller speakers than on large woofers, though. The woofer cones are more mechanically active. But I patched a couple of 15-inch cones that had been punctured for a friend, and they are still playing after a year. So it can't hurt to try.
Jan 30, 2011 | Audio Players & Recorders
I have a 13w7 and i am wondering if its possible to find the replacement foam around the top of the speaker. mine has a tear in it and i find it hard to believe that the speaker would be wasted because of...
The foam is molded, you can not remold / repair
If it is a small tear you can repair with a bit of rubber cement. Eventuly it will fail and more will tear causing the sub to sound very bad
Sep 27, 2010 | Jl Audio 13W7 Car Subwoofer
I have a set of teac speakers that are about 40 years old and I need to replace a woofer. I just do not know which one to buy. The speakers were bought in Germany, the model number is LS-80 and they have...
These sound like they a JBL speaker.
1. You will need the impedence and diameter spec and the Hz (hertz) specifications to get a replacement set.
you can call JBL Altec-Lansing is the company that manufacturer this series of speaker.\ On the back of you speaker cabinet should be a phone number to the company or check the user manual that you received with the speaker system and they should be able to give full information on how to replace the speaker in question or where to have it repaired.
The cabinet is glued together and will need a cabinet expert to disassemble.
Contact JBL for more information.
Mar 10, 2010 | Electronics - Others
How To Remove JBL Model L46 Woofer
Get a metal 1" wide thin spatula and tap it in between the speaker and the cabinet. The 117 woofer has a large flat side. Work your way around the frame and gently pry it up. Good luck. Pointblank
Dec 09, 2009 | JBL Audio Players & Recorders
I have a 2000 toyota avalon and the woofer speaker is buzzing and crackling. a new speaker is $300. is there another replacement beside a stock jbl? will another speaker (cheaper) fit?
I bought a refoam kit from Midwest Speaker Repair - found them on eBay. Cost $23.50, including shipping. Had it in two days. Very easy prep and installation. I think the subwoofer sounds better than new, but I could be wrong. Best way to go. Worth every penny.
Sep 07, 2009 | 2000 Toyota Avalon
Cerwin vega at60 and dc1515
It is called "dry-rot" and it happens with age to paper cone speakers. I am not aware of any products made to help prevent this problem. But you can always replace the woofers with new one's or find a place that "recones" speakers and that would solve your problem for a long time. If you have rubber surround on the cones, it would take much longer to have any type of dry-rot problems. The "foam" type of surround on the cones is the worst for this problem. Most new woofers have polypropelyne surround of the cones and it would probably outlast you, so replacement with a good quality woofer really is a good option.
Jul 08, 2008 | Cerwin Vega CLSC-15S Subwoofer
JBL LSR2325P Powered Studio Monitor Logo
168 people viewed this question
Top JBL Computers & Internet Experts
Carlos L. Burgos
Carlos L. Burgos
SHIVAJI YADAV
SHIVAJI YADAV
mukhtar21 shaikh
mukhtar21 shaikh
Are you a JBL Computer and Internet Expert? Answer questions, earn points and help others
