Question about Briggs & Stratton Garden
Briggs &stratton 11 hp
Motor backfires thru carby
    New Friend:
  • 35 Answers
Timing issue. Remove the flywheel to see if it has "spun" from the keyway. If the motor doesnt run at all but just backfires thru the carb, it could also mean really bad intake valves, but I would definitely check the timing first
Posted on Oct 09, 2014
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
  • 61 Answers
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
Posted on Sep 06, 2009
mowerman1857
  • 389 Answers
SOURCE: 1979 briggs and stratton 11 hp how to fix
If it is, as you say, a 1979 or so engine, the crankcase breather could have well worn out. This will cause the oil burning and blowby. Replace the breather as an assembly, they are cheap and available from any Briggs dealer. The leaks are probably loose bolts and/or bad gaskets. You will just have to figure where the leaks are and replace the appropriate gasket. The breather could also cause the leaks so do the breather first then run it for a while to see if it is still leaking
Posted on Sep 22, 2009
SOURCE: Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Posted on Sep 30, 2009
rwvanlue
  • 486 Answers
SOURCE: i have a 24 hp briggs & stratton els 725 motor
The engine ignition can be interupted by a safety switch (seat) out of place or adjustment, or a carburetor fuel solenoid that is loosing it's supply of voltage.
1) Check the wiring at the starter area, looking for a main engine wiring harness plug-in.
Check for connections that are burnt or loose.
2) If you can locate the 'kill' wire connection at the main harness, disconnect it, and retry the engine.
3) If the engine continues to fail to run properly: you might replace the plugs first, then I have listed a few things to check. They may not all aply, but this may help with an idea or two to try.
1) Determine that there is spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Fuel Related issues that take a certain amount of time to appear
Depending on make and model of mowers:
a) Fuel tank outlet plugged (some have a screen filter,
some are 90' angle and plug with rust and debris inside the corner of fitting)
b) Fuel lines collapse when they are routed thru fasteners and between frame and seat decks
c) Fuel cap vent clogged
d) Fuel filter clogged
e) any fitting that has an orifice that can trap debris or rust will eventually become clogged
f) fitting on the side of the carburetor
g) some systems have a filter inside the line at the opening of the carb inlet
h) fuel pump
i) vacuum hoses to fuel pump
j) debris under inlet needle/seat on carb
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 23, 2009
Hey iv got as GV650 Aquila it wont start the motor turns over no problem but wont Start any suggestions?
check for spark plugs and try to push start button at the same time while the fuel pump motor refreshes. there is also a fuel filter through the fuel is pumped to the jets. if this filter is jammed by dirt particles then also you can experience the same problem.
Jul 31, 2015 | Motorcycles
What causes the motor to backfire thru the exhaust? When I adjust the timing the carborator backfires?
Backfire through carb is timing too far advanced.
Backfire through exhaust is timing too retarded.
May 17, 2015 | Motorcycles
Motor keeps revving up by itself
Usually carby or manifold has air leak most of the time a small hose has been blown of when engines backfired just have a good look around at all the black vacuum hoses and that will fix problem seaya Neil
May 18, 2014 | Cars & Trucks
Back firing
plug not correct or ignition circuit broken
Apr 21, 2014 | 1985 BMW R 65 LS
Backfire through one carbi
this help at all ?
suzuki gsx 600f tuning by ysy 0
as they say a valve .....get a cylinder compression tester
back fire could be timing
Apr 10, 2017 | Suzuki GSX 600 F (Katana Motorcycles
Triumph herald backfires
check the vacuum hose to the carbies There is a hose that controls the plungers in the carbies
Nov 07, 2013 | 1988 Ford F 150
Scag wildcat STWC61V-26KA-LC backfiring
check for loose carby or failed carby to manifold / head gasket as it appears that you have a lean mixture problem xcheck for blockage in main jet.
Jun 12, 2013 | Garden
Backfiring through carby and exhaust
Sounds like the carby is flooding.
Have you had it off?
Try putting a new fuel shutoff valve and seat in.
Set the proper float level.
Make sure that the float does not have a hole in it that makes it sink.
Aug 19, 2009 | Harley Davidson XLH 1000 Sportster...
Garden Logo
143 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
