Question about Car Audio & Video
801 manual best way to clean blocked heads
Instruction Manual for Bernina 801 - need instructions for oiling the Bernina 801
Hi Jim&Bev, The link below in a 23 page user manual for a Bernina 801 Sewing Machine, I hope this helps.......CHEERS..
Bernina 801 Owner Manual
Apr 16, 2016 | Bernina Sewing Machines
Print head error on genesis s 801
It could be a problem with the printhead. Please contact our technical support team via phone so they can check the warranty of your printer. Have the serial number of your printer handy prior to calling our support team.
Jan 16, 2013 | Lexmark Genesis S815 All in One Printer...
I recently changed my carriage belt.The print quality has ever been so bad.Does not print clear lines,especially with the black ink.Always have some white lines within...Thank you. Nima
The printhead for black ink cartridge could be blocked.
It is better to run the Clean Printhead operation on your printers tools option.
You can manually clean the print head so that next time when you execute the Clean Printhead from HP solution center it will be successful.
First, remove the printheads.
then, pull up the lever at the top of the cartridge holder, this releases the print head.
The print head could be blocked, most common is the dried ink blocking the small holes in the print head.
Washed it in running tap water. It is best if you soak it in a mixture of water and ammonia and leave it overnight.
After soaking, you can spray it with canned air and blow those little holes to unclog it. Once it dry, return the print head and the ink cartridges and performed the alignment.
this video will show you how
May 25, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Printer will not print red. The red cartridge seems fine, with ink flowing freely, but it won't print onto the page.
its the problem of print head in your printer. You are not the only one facing this problem there are many other users facing this same problem.in canon printer users out of 10 users ---- 8 users face this problem.
Now I will explain the problem
In the printer where you insert the cartridges is called carriage.in the carriage there is a part called PRINT HEAD. In the print head there are tiny – tiny holes from where the ink passes.when you insert the cartridge in the carriage /head of the printer the ink from the cartridge passes from the head.but if the head is got blocked then the ink will not pass from the head and you get no print out still with the new brand cartridges.now in the printer there is a in built cleaning assembly , so when you give the command of cleaning from your pc/laptop the inbuilt cleaning assembly tries to clean the blocked ink in the tiny holes of the head.but if the ink is got stuck up hard the cleaning assembly in the printer does not have that much power to clean the ink in the head.the other procedure to clean the head is a manual cleaning.in this procedure the head needs to be removed from the printer by disassembling the printer.but in this case out of 100 only 4 to 5 heads gets cleaned and start working but that also don’t last long.its not any guarantee that how much the manually cleaned head will work.
In some cases it has been seen that ink gets used only in cleaning but after inserting new cartridges the printer starts working.if you have inserted new cartridges in the printer and still don’t get any printout then its advisable that you go for any other brand printer.hp is the best brand of printer. Or the other option is you take the printer to local printer repair shop to get the head manually cleaned if you at present don’t want to invest in new printer.a repair center have some special tools to clean the print head its 50 ---- 50 Chance.you can try that first.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
5440CN will not print black after new cartridge and cleaning several times.
Hi
Has it been standing for a long time with out ink if it has then I think myself the head on it is blocked or some times it will take over night for the ink to work, but if the head blocked you need to get at the head to clean it some times if you get a cloth with a little worm water and dabbing it till it clean it will then work.
All the best: pineworks
Jan 26, 2010 | Brother MFC-5440CN All-In-One InkJet...
Printer works as normal but ink does not print onto paper. I am using compatible cartridges and not true epson cartridges.
Hi Compatible Cartridges are not always good to use they do block the heads of the printer some times I used them myself and had the same problems and in the end lost my printer not worth it, if the heads are blocked you need to try to clean them some how, there is cleaning fluid you can buy for this if your heads are blocked, or use worm water on a cloth by dabbing on the heads may clean them be careful not to much water on cloth.
But I would change the inks first buy the right ones for it.
All The Best :Pineworks
Jan 24, 2010 | Epson Stylus CX4200 All-In-One InkJet...
I have a zyxel p600 series modem connected to a Belkin wireless router. I am trying to run a web server on port 80. The modem was using port 80 for access to the internal settings. I changed that to...
Your setup looks correct to me. It might very well be that your ISP is blocking port 80. Go here and check from your server if port 80 is accessible.
If you are the only one that wants to connect to you server, you can simply choose another port to use, i.e. www.myserver.com:801. Set port forwarding form port 80 to 801 in your router.
TCP&UDP - from 801 - to 80 - [serverIP] - [Webserver]
The better way is to use a service like DynDNS.com or No-IP.com. You can register a DNS name (like myserver.dyn.com), which redirects to your public IP. The trick is to update your IP address, so even if you have a dynamic IP assigned from your ISP, the redirect will point always to your server. Most routers have the ability to set up with DynDNS, so the process runs in the background and you don't have to update manually - check your router manual.
The second part of this beauty is the redirect to a different port. So even if your port 80 (and 25 for that matter) are blocked, you don't have to have an arbitrary number in your URL (http;//myserver.com:801). You can find more detailed information here.
For a quick check, change your webserver to run on port 801, enter the redirect in your router and see if you can get to your server from the outside (internet). If you still can't access the webserver, the problem is not a blocked port.
Hope this helps, but if you have any more questions, just come back here and leave a comment - I'm happy to help you figuring this out.
Oct 23, 2009 | Computers & Internet
Head gasket?
You remove air filter and other parts.
Then you remove head cover.
Then you unscrew and remove the head,
Clean a bit the block
Replace gasket.
Screw back the head
Follow head tourqe settings and screw orders on diagrams when mounting back the head.
The whole thing is not thst easy as it may seem, if you want to DIY you will need to buy the Haynes manual for your car. There you find a step by step procedure with pictures.
Here is a repair manual.
Also enquiry to Haynes.Haynes manuals are the best.
Here is how to replace head gasket on a Honda,
with lots of pics, procedure is the same, torque values and screwing order are different. It is not a job for absolute beginners
Do not forget to rate the solution
Thanks.
Aug 31, 2008 | 2000 Daewoo Leganza
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
