Question about IBM Computers & Internet
I have server x3620 m3 after electric turn off server can't boot and message display on black display Uefi Platform Initialization.how to fix this problem.thank you
    Sergeant:
    Novelist:
  • 143 Answers
Still an issue?
Posted on Jun 13, 2015
3 Suggested Answers
springga
SOURCE: IBM System x3400 M3 7379 not booting displays orange colour (!), hangs at EFI Initialization what might be the problem. Thanks in advance.
check the indicators on the right side of the front panel for more detail of the error. search online for the manual.
Posted on Jun 25, 2012
  • 143 Answers
The is an known issue on IBM M3 server models . It could either be a Motherboard or memory issue .
Check if there any amber on Memory . If there clean it and refix . Check amber comes again . If there replace memory .
If there is no amber on memory , then it could be a motherboard (UEFI firmware hang ) issue.
Replace it
Posted on Aug 07, 2012
Is it possible to fix my desktopPC?
Not compatible. Make a flash drive/CD rom of your OS and start again.
Aug 07, 2016 | Acer Computers & Internet
"BIOS NOT INSTALLED"
If your server boots and then displays this error, it may be referring to one or more adaptor(s) installed and their BIOS need updating. (Though you do not need them for the server to function.) If your server will not boot due this error, you need to update the firmware via usb or network connection.
Good Luck.
N.I.T.
Mar 27, 2014 | IBM x3550 Server
Uefi platform initilization
This would probably a motherboard issue. Sometimes firmware updates(Uefi and IMM) can resolve issue.
Same message appear when server has memory faults also, so check memory has no amber.
You would have to for motherboard replacement when no memory issue found on server
Thanks
Dec 16, 2013 | IBM System x3400 M3 7379 Server tower 5U...
Windows 7 with Gigabyte motherboard says "ntldr is missing"
Check if UEFI is disabled after flash with newer BIOS version. If you flash BIOS the default settings gets loaded again. Check hard disk settings and boot settings.
Mar 03, 2013 | Gigabyte Computers & Internet
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
Nov 28, 2011 | IBM System x3400 M3 7379 Server tower 5U...
I need ibm x3200 m3 (7328) setup installation image?
IF you are looking for fresh installation , you need server guide cd which has the option to create raid and contain all drivers for the server
Download it from the below link
Hey its a image file , so download it and write it in cd. Make boot option from cd then.
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5079561
Hope this would help
Thanks
Feb 15, 2011 | IBM System x3200 M3 7328 Server tower ...
Describe your dell dimension E521 wont boot and Problem my computer turns on but doesn't open it goes to a black screen with little flashing bar in top left corner nothing new was installed but there...
The 123 lights on tower translates as:
Routine system activity subsequent to video initialization.
Watch your monitor for on-screen messages.
Disconnect the video cable from the computer and see if you get floating color bars on display. If not, your monitor is defective.
Jan 10, 2011 | Dell Dimension E521 PC Desktop
I have A radio shack PRO-2096 and have not been able to use it in over A year. it reads all channels locked out. I can't unlock it.can someone please help me?
Please try this!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Computers & Internet Logo
246 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
