Question about Weather Channel VEC1198 Radio
1.Is the 9-watt cfl bulb replaceable and if yes which stores
1.Is the 9-watt cfl bulb replaceable?And from which stores?
2.Is it any 12v dc adapter that can recharge its battery?
  • 11,896 Answers
The bulb is replaceable. You can get the bulb at radio shack and also from the company website.
Posted on Jun 23, 2009
What type of light bulb do I need for a minkaAire ceiling fan. It is about 7 years old
It all depends on which light kit was installed on your fan. As you described the fixture as requiring a "light bulb" meaning a singular bulb, Minka Aire usually uses several different types.
The most common is either a 40-watt or 60-watt Candelabra Bulbs.
(The designation "Candelabra" refers to its screw base. You can buy these in clear or frosted, torpedo or globe with a straight tip or curved. Etc.
Here's an example of a torpedo globe:
Sunlite 60 Watt Torpedo Tip Chandelier Candelabra Base Frost 48 Pack
And here's an example of a Candelabra globe:
Sunlite 60 Watt G16 5 Globe Candelabra Base Clear 48 Pack
Some of their fixtures use a 50-watt Mini-Can Xenon Bulb.
Satco S1914 50W MINI CAN FROSTED 120V
And other use a 3w CFL Medium Base Bulb.
3W CFL Deco 2700K Medium Base
When installing a CFL, Halogen or Xenon bulb, I recommend cleaning the glass with an alcohol wipe to remove any oil from fingerprints. Due to the very high temperatures these lamps operate at, the oil from your fingers will cause a hot-spot on the glass and can shorten the life of the bulb dramatically.
If none of the references I offered match the bulb in your actual fixture, you might be able to more closely match the fixture from one on the following page. The recommended bulb for each fixture is listed in the description of the fixture.
https://www.ceilingfan.com/Minka-Aire-Fan-Lights-s/2082.htm
And as always, NEVER over-lamp a fixture with a bulb rated at a higher wattage than what's shown on the base of the fixture. That is, never use a 60-watt bulb in a fixture rated at 40-watts. The additional heat of the bulb may harden the insulation of the wiring in the fixture creating, causing the insulation to fail and create a fire hazard. Also for fixtures located tight to the ceiling, higher temperatures can dry out the gypsum ceiling material, causing it to crack and deteriorate.
Feb 09, 2018 | Dryers
Can I use a 23W CFL bulb in place of a 13W, if the desk lamp says to use a 60W max bulb?
OF COURSE less than 60 watts is it not . and they are a lot cooler
May 08, 2015 | Dryers
Can I replace the 13 watt CFL bulbs in my fan light fixture with a higher watt bulb
The bulb fixture itself should tell you what the max wattage is that you can put in there but they are normally at a 60watt limit.
Feb 25, 2015 | Hampton Bay Dryers
CFL light bulb dangerous?
Yes they are. Look up the HAS MAT procedures you should follow when you break one. I use LED lamps, they are much safer and greener as well. They also come on full brightness after years of use.
Dec 19, 2014 | Dryers
Compact Flourescents won't work in ceiling fan
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
Dec 17, 2013 | Hunter 52" Ceiling Fan With Light And...
Can I replace the 3 40 watts bulbs that came with my Hampton Bay Hawkins 44" ceiling fan with 3 60 watt bulbs?
You would be better off getting 3 40watt daylight bulbs.. extreamly bright low cost and wont cause any harm to your fan.. hope this helps :)
Oct 21, 2011 | Dryers
Can i use a standard light bulb in a ceiling fan?
Probably 60 watts ... 60 is pretty much the limit I see on these devices.
So, you want more light, use CFL's in your Hampton Bay. You can use as large a CFL as will physically fit into the globe, consistent with remaining below the max watt limit. CFL's put out more lumins per watt than conventional light bulbs do. (Compact Flourestent Lamps)
Find CFL at a retail store near you - hardware store, big box store. LCD are another alternative for your consideration. Find LCD at http://www.ledlightbulb.net/ ... and here http://www.google.com/products?hl=en&resnum=0&q=led+household+lighting&um=1&ie=UTF-8&ei=G36BS4rjG5WWtgf39OnhBg&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CC4QrQQwAw
There are probably a lot of other sources for these specialty lighting products. Perhaps you could see a demonstration at a lighting distributor store in your area. Be prepared for a pricy product. I thnk LCD are around $20.00 each while CFL are probably $8.00 each or more.
I hope I have helped you with your question. Thanks for your interest in FixYa.com
Feb 21, 2010 | Hampton Bay 37225 Cameron II Plus Fan
Weather Channel VEC1198 Radio Logo
141 people viewed this question
Top Weather Channel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Weather Channel Audio Player and Recorder Expert? Answer questions, earn points and help others
