Question about Konica Minolta Office Equipment & Supplies
Fault code 4653 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
What model #######
Posted on Dec 29, 2015
MY YBR ENGINE MANAGEMENT LIGHT FLASHES 3 SHORT FOLLOWED BY 3 FAST
That indicates fault code 33 which is a faulty ignition coil
Fault code 12 - Crankshaft position sensor
Fault code 13 - Intake air pressure sensor
Fault code 14 - Intake air pressure sensor
Fault code 15 - Throttle position sensor
Fault code 16 - TPS
Fault code 19 - No signal from ignition to ecu
Fault code 22 - Intake air temp sensor
Fault code 28 - Engine temp sensor
Fault code 30 - Tip over sensor
Fault code 33 - Igniton coil
Fault code 39 - Fuel injector
Fault code 41 - Tip over sensor
Fault code 44 - Read write error ECU
Fault code 46 - Power supply error to FI system
Fault code 50 - Ecu malfunction
Jan 08, 2015 | 2009 Yamaha yBR125
How do I fix code 13 engine speed sensor Above 1000 rpm
Clearing the codes is simple that is done by removing the fuse of the EFI from junction box 2 for 10 seconds. Make sure to remove the jumper wire and switch the key off before clearing the codes.
Here are some common Lexus vehicles 1990-1995 codes:
Code 12 and Code 13 Rpm signal circuit fault
Code 14 Igniter signal circuit fault
Code 16 ECT control signal fault
Code 21 and Code 28 Main oxygen sensor fault (for ES300; SC300 & GS300 models)
Code 22 Coolant temperature circuit fault
Code 24 Intake temperature sensor circuit fault
Code 25 and Code 26 Air fuel ratio fault (for ES300 & SC300 models)
Code 27 Sub-oxygen sensor circuit fault (for ES300 CA & GS300 models)
Code 31 Low airflow meter voltage (for ES300 and GS300 models)
Code 32 High airflow meter voltage (for ES300 model)
Code 35 Barometric pressure sensor circuit fault (for GS300 & SC300 models)
Code 41 and Code 47 Throttle position sensor circuit fault
Code 42 Vehicle speed sensor circuit fault
Code 43 Starter signal
Code 51 Switch condition signal fault (for ES300; GS300 & SC300 models)
Code 52 Code 52 and Code 55 Knock sensor circuit fault
Code 71 EGR system circuit fault (for ES300; GS300 & SC300 models)
Code 78 Fuel pump control circuit fault (for GS300 & SC300 models)
Nov 18, 2014 | 1990 Lexus LS 400
Why can't i email swissamerica.com
Mailing Address: 15018 N Tatum Blvd Phoenix, AZ 85032 Toll Free: (800) 289-2646
Phone: (602) 788-4653 Fax: (602) 788-4655 Director of Administration: Bronwin Barilla -- bkbarilla@swissamerica.com Toll Free: (800) 950-2428 Director of Marketing: Holly Smith-- hjs@swissamerica.com Advertising Agency: FAME - Financially Acclaimed Marketing Enterprises, Inc.
Pat Mershon - President admin@swissamerica.com
Jun 17, 2014 | Computers & Internet
The top part of the freezer compartment is warming up and setting off the alarm. Liebherr 7080 207-01 model
I also had defrost problem with Liebherr 7080 207-01. I removed freezer back panel, I defrosted all ice with hair dryer, but the freezer is not done for manually defrosting!!! You may have problems removing the back panel (I was not able to remove it with a screwdriver and i decided to pull it beaking the plastics supports and thean I put it back. It is a shame !!! Now it is working much better. I think this will be my last Liebherr freezer!
Oct 18, 2012 | Liebherr Refrigerators
Need code for 2004 chevy optra am fm cd player
try one of these :
1165 1325 1341 1630 2145 2152 2346 2453 3116 3241 3451
3462 4156 4236 4265 4316 4353 4362 4513 4524 4553 4653
5224 5226 5241 5253 5256 5436 5624 5813 6253 6361 6461"
May 20, 2010 | Toys
Trouble Codes
1. VW VAG type 5 digit fault code 19497 = EOBD type P3041 fault code:
Fault location = CAN data bus, instrumentation - implausible Engine Coolant Temperature (ECT) signal
Probable cause = Wiring, matching resistor in Engine Control Module (ECM)
2. VW VAG type 5 digit fault code 18032 = EOBD type P1624 fault code:
Fault location = Malfunction Indicator Lamp (MIL) - request signal active
Probable cause = Trouble code(s) stored in other system(s)
3. VW VAG type 5 digit fault code 01039:
Fault location = Coolant Temperature Sensor (G2)
Probable cause = Open or Short to Plus, Short to Ground - Intermittent
4. VW VAG type 5 digit fault code 01304:
Fault location = Radio
Probable cause = No Communication
5. EOBD type P0761 fault code:
Fault location = Shift Solenoid C
Probable cause = Performance or Stuck OFF
Feb 03, 2010 | 2002 Audi A4
Need raido code for 2001 daewoo leganga please
1165 1325 1341 1630 2145 2152 2346 2453 3116 3241 3451 3462 4156 4236 4265 4316 4353 4362 4513 4524 4553 4653 5224 5226 5241 5253 5256 5436 5624 5813 6253 6361 6461
Posts: 4 Radio Code List:
6361,LEGANZA 99
2253, 3116, 3451, 2152, 4362, 4316
4316, 4513, 4362, 1156, 2145, 1156
6451, 6361, 5624, 5241, 3346, 1165
3241, 4524, 5436, 5813, 3265, 5624
2453, 3462, 3251, 5445, 8253, 1156
2346, 4853, 6645, 5253, 1325, 4136
3116, 3221, 2151, 5312, 2654, 4314
6234, 4356, 1415, 1435,1156, 1651
6361
2152 1165 4362 5813 4513 5241 4316 1651 5346 1341
3241 1652 4524 6361 2145 5436 1857 4353 5632 3451
1638 1156 1636 5324
Dec 09, 2008 | 2002 Daewoo Leganza
RCA EXECUTIVE SERIES 50029864
If you are looking for a message on hold port, you will not find one. Technically speaking, this is not a phone "system." There are 2 options for using messages on hold with your phones:
1) Using a message on hold player with a built-in adapter
2) Using a message on hold player and a separate adapter
The best option can be a little tricky to determine. We work with hundreds of small businesses that have 2,3,4 line phones and can help you figure this out and deliver the best solution. Please call me.
800-832-4653 ext.240 (Drew, Sales Mgr, Commercials On Hold)
Dec 27, 2007 | RCA 25403RE3 Corded Phone
It hums, but doesn't pump or wash
you may have a bad motor. I would check the float switch it is the round hat looking thing on the left side. it should move up and down easy.. you may need a repairman to change out the motor/pump..let me know thanks
Aug 25, 2007 | Maytag PDB3600A Built-in Dishwasher
42 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
