Noisy spinner on my service washing machine 3yrs old
It is very noisy when on a spin no oil leak
  • 1 more comment
  • Anonymous Dec 02, 2007
    louud bang noise in spin
  • wezoom Feb 11, 2008
    Washer is very noisy on spin cycle and also vibrates utility room. Washer appears to be level and balanced ok. Is 6 years old, but is only used for two people.
  • weezebnice Nov 20, 2008
    Splendide 2100 is noisy when spinning. Sound is present also when machine is off and the drum is turned by hand. The noise is less when the load of clothes is small.
Sounds like the main bearings need replacing, get an estimate, it may be time to replace your machine
Posted on Nov 05, 2007
  • 248 Answers
We need to know the brand and age. Model would help.
Maytag centennial washer
Dogs inside of spinner are worn out. Take screw off top of spinner and you will see four dogs that are easy to change.
Sep 30, 2017 | Washing Machines
Bosch Maxx 5 very loud noisy spin
the spinner to motor coupling is damaged by the wear and tear..please replace it
Aug 24, 2012 | Bosch Washing Machines
My neptume will not wash clothers. the tumbler
if it's noisy in the spin i'd be in the market for a new washer,there's a spinner support assy. that goes in the rear of the drum,for the price it will cost for the part and labor you'd be close to a new washer
Feb 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire front load washer GLTF1240AS0 - noisy and leaves dirt/oil on clothes in dotted pattern (so dirt being put on thru drum at final spin?). Could it be oil leak? bearing?
good call.....
your bearing is leaking into the machine
you can verify this by simply removing the back
if the side walls are covered in ablack spray pattern
sometimes it does not leak on both sides (in and out) but if it is leaking your machine will get progressive louder in both aggitate and spin
Oct 09, 2009 | Frigidaire GLTR1670A Front Load Washer
How do I clean the filter on a Bosch Exxcel washing machine? White washing (especially bedding) comes out of the machine with dust like particles all over it that are very difficult to remove.
is this dust or OIL, if its oil its perhapsdue to faulty drum bearing /leaking is the machine noisy on spin ? this is an indication of this...
Oct 01, 2009 | Washing Machines
Neptune Washer Clutch/spinner failure
Take a look thru this post and see if it the SM and Sears Parts direct link will help you. I have some pic’s of the clutch and a step by step to process to remove and replace the clutch in the FAV6800AW machine. I’m an owner like you not a repair person. I’m not sure what the repair service is calling spinner bearings. I believe they are referring to the roller clutch bearing assembly. If you are not leaking water on the clutch (Tub seal issue) I would drop the clutch out inspect and go from there. Are you throwing any error codes to the console such as “dc” or “UC” in the spin cycle of the wash cycle The repair service seems to be going in the right direction did you get a $350+ quote to repair? Does the machine spin dry the clothes to hang dry/dryer ready OK? I feel you have nothing to lose if you want to try a DIY fix and I will help as much as I can. Rich
May 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Transmission oil is leaking into the basket of wash and staining clothing. the unit is 3 years old. repair service said to contact you for repairs since it is covered for 5 years.
sounds like the water seal in front of the drum bearings has failed causing grease from the bearings to get into the washtub this is usually accompanied by noisy spin cycle and rumbling noises from the drum when it is turning
Jul 15, 2008 | Whirlpool Washing Machines
Washing Machines Logo
309 people viewed this question
Top Washing Machines Experts
