Question about Tecnik TKC1285 Dual Fuel (Electric and Gas) Kitchen Range
Gas ring on range cooker doesn't work - Tecnik TKC1285 Dual Fuel (Electric and Gas) Kitchen Range
What is likely to be involved in repairing gas leak from 2 hob rings in Flavel Milano 100 Cooker?
get in a gas fitter to do the job so that the jib can be certified as safe and all of the correct fittings can be used
Feb 21, 2018 | Kitchen Ranges
What cooker spare do i need for a low flame?
Is the cooker running on a gas bottle or mains gas?
Is it one ring that is affected, or the whole cooker?
Jul 31, 2014 | Rangemaster 110 (Gas) Kitchen Range
I want to install a richmond 1000df range cooker on a peninsula kitchen unit. there is a gas pipe which comes from under the floorboards to the location. Is this going to be possible? ive heard you need to...
You must , by law be a registered Gas Safe Engineer to connect this cooker to the gas point , they will also chain it for you. You can find a Gas Safe engineer at www.GasSafeRegister.co.uk then , enter your postcode in the required box and you will be given a list of Gas Safe engineers in your area or ring freephone 0800 408 5500 to get this information .
Apr 06, 2010 | Stoves 1000DFDL Dual Fuel (Electric and...
Need to know if my cooker is a bayonet fitting
the bayonet fitting is on the end of the gas pipe that plugs into the gas main. look at the back of your cooker follow the black pipe you will see a brass end that fit to the solid gas pipe if you have a ring on the end of you flexible pipe that you can push in slightly and turn to disconnect you have a bayonet. its not the cooker that is a bayonet but the flexy pipe that is connected to your cooker. you can add one if one not fitted
Feb 02, 2010 | Belling Solitaire G755 Gas Kitchen Range
Gas cooker, the oven works but no gas going to rings
you need to check the pipe that take gas in to rings , and check the adjuster button .... where you live may be i can help you
Jan 25, 2010 | Kitchen Ranges
Some rings work, some don't on hob
Hello both of you,
my first impression will be dirt in the injectors.
I suppose this top has removable injectors. Normally you can remove them with a 7mm socket
tp021264-1-bxvwimtpanuivq3sgra5z31g-5-0.jpgAs the pressure is really very low in the grid, every single part of dirt in that little hole will block the gasstream.
When I refurbish a cooker, I always clean these thoroughly.
I wish you succes, Dik
Aug 02, 2017 | Rangemaster Proffessional 110 Gas Kitchen...
COOKER HOSE
It is illegal to fit a cooker to a gas connection unless you are a registered Gas Safe Engineer . You can find one in your area if you visit www.GasSafeRegister.co.uk
Jun 09, 2008 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Kitchen Ranges Logo
21 people viewed this question
Top Tecnik Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Tecnik Kitchen Range Expert? Answer questions, earn points and help others
