Question about Sharp Office Equipment & Supplies
WorkCentre C226 CE-02 Error solution
What is the workCentre C226 CE-02 Error solution
SOURCE: Network Error CE-02
Error ce-02 means that the computer the image is being sent to is not running sharps "network scanning tool" which is part of the sharpdesk software suite
Posted on Jun 25, 2008
There is a Windows Port that is being blocked. First make sure the IP it's scanning to and IP on the machine are the same. disable the firewall. I'm working on narrowing down the port now and will post as soon as I find it.
-Mike
Posted on Nov 25, 2008
  • 143 Answers
SOURCE: getting a CE-02 error when trying to scan.
1) Check that the Network Cable is
inserted properly.
2) Check that the connected network
supports TCP/IP protocol.
3) Check from the Web Page that the
Primary/Secondary E-mail Server
Address or the Destination FTP server/
Desktop PC address are properly set.
4) If the above address is described with
Hostname, check that the DNS server
is properly set.
5) Check that the SMTP server/FTP
server/NST causes a trouble or not.
Posted on Jun 26, 2009
  • 120 Answers
SOURCE: sharp arm 450n (ce-02)
1) If you're actually scanning to an email address, make sure your SMTP email server information in the copier's web page is correct.
If you are using names instead of IP addresses, also make sure your DNS server IP's are correct.
2) If you're scanning to create the fake email set up by Sharp Network Scanner tool, the connection info in your copier is old and needs to be refreshed.
From the computer you're trying to scan to, right click on the Network Scanner Tool icon in the tray, go to Automatic Profile Update, and select Update Now. If you have no tray icon, reboot your computer.
If your copier is set up to store names instead of IP addresses, make sure your DNS information is correct in the web page.
Posted on Jul 09, 2009
acsmappel
  • 61 Answers
SOURCE: Xerox Workcentre C226 - Error H5-01
This might help, but I don't know how to put it in tech mode.
"The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on."
Posted on Aug 04, 2009
I HAVE A XEROX WC 226 THAT THE COPIES ARE LIGHT
If you don't have it, here is a link to the quick start guide.
http://www.manualslib.com/manual/339328/Xerox-Workcentre-C226.html
look on page 7 for the image quality button and adjust as needed.
Feb 24, 2015 | Xerox Office Equipment & Supplies
I have a Sharp AR-M550N; It's giving me a code Network error CE -02? How can i solve that error?
CE 02 is rarely a machine problem, It normally is an addressing problem between the machine and the network. That code indicates a communication problem, normally relating to scanning.
Often times it is a wrong character in an address.
Feb 01, 2011 | Sharp AR-M550N Copier
What is Network error (CE 02) thank you
Network Error CE-02 - this is where the machine cannot communicate with the SMTP Gateway / Mail Server for scanning. Check that you have a connection with the network and that you have the correct SMTP I.P address.
If you are using a host name for the mail server make sure that you have configured the DNS entries correctly.
Hope this helps.
Feb 01, 2011 | Sharp AR-M455N Copier
Our machine is a Sharp AR-M55OU and it is giving us the error CE-02 when we try to scan. What does that mean?
I believe the CE-02 is a generic network error.I had the same issue, with us it was a DNS issue. We had old computer accounts in DNS confusing the scanner when using hostname. Have your network admin scrub DNS and see if it solves it.
Sep 03, 2010 | Sharp AR-M350U Copier
Xerox workcentre pro 5225 exrror code 026-714
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
Feb 26, 2010 | Xerox Workcentre 5225 / Copier, With...
Jul 29, 2009 | Office Equipment & Supplies
Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
Apr 09, 2009 | Sharp AR-168D Black and White Copier
CE-02 error code when scanning on SHARP MX-M550U copier
ce error means not hooked up property to your email server
Feb 12, 2009 | Office Equipment & Supplies
Network Error CE-02
-Mike
Oct 31, 2008 | Computers & Internet
Drivers for PCL5c printer/copier for mac
Basically all priners use the same protocols. Mostly we have PPD and NOW PCL5.
Right now I´m using a workcentre c226 however all the drivers I found on the Xerox homepage were PPD... they didn´t work. This is what I did:
I whent to Sistem Preferences->Print&Fax->(select your printer in the left side)->Options&Supplies->Driver->Select Driver to use...
Now using spotlight or reading all the drivers search for a printer that uses PCL5 and thats it. It doesn´t mater if its not the model you have.
For example with the WorkCentre c226 I use the driver of a HP LaserJet 3P w/ PCL5.
Jan 17, 2008 | Office Equipment & Supplies
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
