the camera is having focusing problems, it wont auto focus at all, i have a 24-120mm lens. after a few seconds the display on the lcd goes blank the shutter speed an the appature doesnt show, can u help me please.
Make sure both lens and body are set for autofocus. There are two switches near each other with "AF" and "M" settings.
Check the camera's focusing settings, or do a factory reset (from menu) to 'start over'. Usually helps to have AF-Assist on.
Try setting the AE/AF-lock button (upper rear, near right thumb when holding camera) to turn on AF. The camera may respond better to this than half-pressing the shutter release.
Make sure the lens is fully attached to the camera. You shouldn't be able to rotate the lens without depressing the lens release button, and you should be able see a tight seal between the two.
Was this helpful?
Yes
No
Popular Solutions for Nikon D70s Digital Camera with
after i take a photo a " job nr" is flashing on the lcd display and it looks like it takes...
(More)
after i take a photo a " job nr" is flashing on the lcd display and it looks like it takes longer to display what i have taken on the display screen.
my nikon d70s will not turn off, when i switch it off it remains on, it still functions as if it's...
(More)
my nikon d70s will not turn off, when i switch it off it remains on, it still functions as if it's on.
I connected my nikon to the D70 to the computer I disconnected it correctly but a notice came up to...
(More)
I connected my nikon to the D70 to the computer I disconnected it correctly but a notice came up to say I hadn't the screen but i couldn't remedy it and after I turned it off t now it wont turn on again.
