Nvstreamsvc.exe Can't get user token [1008] - Computers & Internet
How do I get my serial number
Download and install free Belarc Advisor (the initial analysis may take a little while) and note the Windows 8 product key displayed in the Software Licenses section.
http://software-files-a.cnet.com/s/software/13/50/18/05/advisorinstaller.exe?token=1410402353_eef7f848bcd705337eaeda3f2af63b49&fileName=advisorinstaller.exe
Sep 09, 2014 | Computers & Internet
0xc004f059
google found this
The problem is caused by the invalid SLIC table highlighted above.
The solution is to rebuild the Licensing Store and if necessary change the Key to the one on the COA sticker on the machine's case
Please first try recreating the Licensing Store.
Recreate the Licensing Store
1) Click Start button.
2) Type: CMD.exe into the 'Search programs and files' field
3) Right-Click on CMD.exe and select Run as Administrator
4) Type: net stop sppsvc (It may ask you if you are sure, select yes)
Note: the Software Protection service may not be running, this is ok.
5) Type: cd %windir%\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareProtectionPlatform
6) Type: rename tokens.dat tokens.bar
7) Type: cd %windir%\system32
8) Type: net start sppsvc
9) Type: slui.exe
10) After a couple of seconds Windows Activation dialog will appear. You may be asked to re-activate and/or re-enter your product key or Activation may occur automatically.
If you are asked for your Key, use the one on the COA sticker on the machine's case
Dec 23, 2013 | Microsoft Windows 7 Ultimate for PC
My gemalto is connected and Ihave an internet connection but cannot access work network
have you been able to access work network before from this unit? if not, they will have to grant you access
Jan 28, 2013 | Gemalto 100 user otp token bundle...
Raid controller driver
Please download the driver from below linkhttp://software-files-a.cnet.com/s/software/10/55/43/69/cnet2_via_raid_v530c_zip.exe?token=1332247542_4c675a70a00eed227b8246a73d7b2cf5&lop=link&ptype=3001&ontid=2122&siteId=4&edId=3&spi=c4419745135d2d4c1a8a2b3d3f10de21&pid=10554369&psid=10251050&isDlm=1&fileName=cnet2_via_raid_v530c_zip.exe
Mar 16, 2012 | Computers & Internet
L want advice on the best bernina to buy, 1008 or 1010. what is the difference between 1008 and 1008S and 1008ES
The machines are the same, the only difference in the 1010 was made from 1989 to 1991, the 1008 in the new version! Both great machines!
Aug 19, 2010 | Bernina 1008
How do I get a free copy of a Bernina 1008 user maual and a repair manual? soft copy or hard copy
You can download the manual in PDF format from www.berninausa.com
Feb 07, 2010 | Bernina 1008
What does ''unauthorized access blocked'' and ''open process token mean''?
unauthorized access blocked means you have no access to that particular object and u are not an authorized person to access it... open process token is way that they tell you that you have no token pass to open that particular process
Jul 29, 2009 | Symantec Norton Antivirus 2009 1-User -...
On startup, i get the message: Isass.exe - Access Denied
Information on lsass.exe - http://www.neuber.com/taskmanager/process/lsass.exe.html
Are you running a firewall (such as zonealarm)? It might be your firewall may be blocking a legit attempt by lsass.exe to run. You may have to add this to your firewall's allowed list. Of course if you are not running a firewall or if your firewall is already set to allow lsass you may have even greater problems.
http://www.google.com/search?hl=en&q=lsass.exe+shuts+down+pc
You may want to post more information to get a better answer on this.
Oct 28, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
