Question about Minolta DiALTA Di183 Copier
Why it show a light on a panel next to a paper sign
  • Minolta Master
  • 6,696 Answers
PAPER JAM or out of paper
Posted on Dec 29, 2014
Check print cartidge light keep blinking and the light on copies showing empty while there is paper in the tray
Issue: The Check Paper and Check Print Cartridge lights blinkIn this error condition , the following blinking lights pattern displays on the control panel:
  • On/Resume light : On
  • Check Paper light : Blinking
  • Check Print Cartridge light : Blinking
  • Black Start Copy light : On
  • Color Start Copy light : On
Figure 79: The Check Paper and Check Print Cartridge lights are blinkingc00864299.gif
    hpweb_1-2_minus.gifCauseThe carriage is stalled or jammed. A message indicating that the carriage is stalled might appear on the computer.You might also experience the following symptoms:
    • The product will not print.
    • The carriage is stuck and does not move.
    • The product makes loud grinding noises.
hpweb_1-2_minus.gifSolutionsSolution one: Turn the All-in-One off and then on againFollow these steps to turn the product off and then on again.
  1. Press the On/Resume button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the On/Resume button (c01602202.gif ) to turn on the product.
  4. Check the lights on the control panel to make sure that they are no longer blinking.
  5. Try the intended task again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Make sure that the front panel overlay is installed correctlyIf the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, follow these steps to ensure correct installation of the front panel overlay.If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
Oct 07, 2011 | HP PSC 1210 All-In-One InkJet Printer
Hp laserjet 2015 printer shows an indicator light error that theres a paper jam but actually no paper jam or paper particles . I have cleaned aii the sensors and checked the paper path. Powers on well...
restart it
if problems insist check if sensors are working
if are working you need to replace motherboard
of your printer that cost to high
you better replace your printer
hope i had help you
Nov 26, 2010 | HP LaserJet P2015 Printer
Blinking lights plus E sign for cartridge error -
Look carefully to make sure there is no paper jammed inside. Sometimes there can be a small piece of paper that tore-off in the gears causing a paper jam.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 11, 2010 | HP DeskJet F380 All-In-One Printer
Triangle with caution sign constantly flashing / no print
Paper jam, top cover is open, out of paper, fuser is bad, or paper did not pickup. All but the fuser is consumer repairable.
Jan 26, 2009 | HP Color LaserJet 2550n printer + HP Color...
Tally T6218 show paper out even if there is paper. what is the solution
Have to enable techmode (go offline and hold the line feed and enter button for three seconds)
then go into the test menu and do the fault override and turn off paper out sensor and then must calibrate the paper out sensor by checking and verifying voltage with paper in and paper out, this is done on the control panel.
Oct 21, 2008 | Tally Line Matrix T6215 Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
Minolta DiALTA Di183 Copier Logo
18 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
