Question about Hotpoint WMA40 Front Load Washer
How do I change the door seal on my Hotpoint WMA40 washing machine
    New Friend:
  • 15 Answers
Best to watch this video on youtube which explains it in detail
Posted on May 29, 2014
5 Suggested Answers
FitzOriginal
  • 842 Answers
SOURCE: Hotpoint Door Seal WMA64
I have reproduced the details of my article: http://www.fixya.com/support/t1543617-door_seal
here. I hope this will give you the information you need.
Rule 1: BEFORE YOU START Turn off the mains, unplug at the wall, turn off the water supply.
The gasket is held in place on the drum by a large sprung wire ring with a screw tighten/release. To access this (Depending on the model), you will either have to go in from the top or the bottom of the machine. Usually the top.
Pull the machine out, go to the back and unscrew, usually 2 screws that hold the "Work top surface" top on the machine at the back. There are usually clips at the front of the top, so by lifting the rear clear and either pulling the top back, or giving it a tap forward, depending on the design, the top should now lift off.
You should now be able to look down at the drum and you should clearly see the rubber gasket fitted over the edge of the drum with the clip in place. Locate the screw in tensioner and undo it until it is possible to slip it forward and clear of the drum. You should now be able to simply pull the gasket away from the drum. Most machines rely on the door being closed to hold the gasket in place where it meets the chassis, it should just pull off if the door is open, but while you are lookiing inside, just check anyway. The assembly is simply a reverse of what is described above.
Stuff to consider: You may not be able to see the screw clip from the top, if so, tip the machine back and look from underneath. If you have to do this: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
Posted on Feb 15, 2009
SOURCE: hotpoint wma40 door seal
You may also have a black well. If you are not using city water wells often have to be bleached out. Have your water tested.
Posted on Mar 20, 2009
  • 197 Answers
SOURCE: How do I change the door seal on my Hotpoint WMA40
It's a push fit seal. Carefully remove the old one and for help, smear the new seal where it fits the machine and just push it into place securely.
Posted on Sep 07, 2009
  • 662 Answers
SOURCE: How to change door seal on hotpoint FEW12 washing machine
For most front-loaders:
Lubricate the slot which fits over the tub with washing-up fluid. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Pl rate me nice for the free help!
Posted on Jun 15, 2010
Hotpoint wma40
hi take the band of rubber just inside door take soap draw out take screws out holding panel this comes of dont pull wires of control panel or mark were they go take kick plate off you have screws holding bottom of panel top ones are under top panel take two screws holding catch out were door clips in push panel up you can get to front of drum to take off takes about 15 min oh sorry top off 1st hope this helps
Jan 29, 2014 | Hotpoint WMA40 Front Load Washer
How do i replace drum berings on a hotpoint wma40,and aprox.cost thank you
the bearings are about $20,the lip-seal to protect the bearings from water is about $45,and if you hire it done you need to find out the labor rates in your area,it can take from 2-7 hours to complete depending on how hard the old water soaked and rusted bearings come out of the bore
May 02, 2010 | Hotpoint WMA40 Front Load Washer
Hotpoint Aquarius Extra WMA40 - Prewash light flashing and cycle not completing? The water level also looks to be very high? As tenants this machine has been installed (we suspect second hand) to replace a...
The water level on the Hotpoint WMA range of machine should be below the door, check out the error code definition at this site. You probably have a pressure chamber blockage or partial blockage. There are also workshop manuals for the Hotpoint WMA & WM machines which run through this sort of repair.
Mar 20, 2010 | Hotpoint WMA40 Front Load Washer
Hotpoint WMA40 washing machine is leaking from detergent drawer- any suggestions ? Thanks
Hotpoint WMA40 washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 27, 2009 | Hotpoint WMA40 Front Load Washer
Brocken door spring
If you have not rectified your problem, you need to seperate the 2 door halves by removing all screws securing the 2 halves, and prize`appart, then you can easily change the spring.
Please rate my solution.
Thanks.
Oct 05, 2009 | Hotpoint WMA40 Front Load Washer
How do I change the door seal on my Hotpoint WMA40 washing machine?
Sep 07, 2009 | Hotpoint WMA40 Front Load Washer
Blocked filter
This is for the WD420, but could be useful for you.
The filter is inside the machine. If you machine is still under guarantee I would try and get it done that way. Otherwise turn off the power and pull out the machine to get a the back.
Remove the panel at the bottom where the discharge hose comes out. You should see a black concertina type tube coming from the drum attached by a jubillee clip. The filter is inside. Losen the clip and pull away the tube take out the filter and clean it. When you replace it don't forget to put the ball float back in and check its well fixed by running a spin cycle before sealing up.
(courtesy pollydolly10)
Feb 23, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint wma40 door seal
The black grime is mold. Once it is set into the rubber it is nearly impossible to remove. Bleach would have been my suggestion but since you've already tried that, replacing the bellows (door seal) is your next option. In the future, when the machine is not in use try keeping the door slightly open for any standing moisture to evaporate.
Feb 19, 2009 | Hotpoint WMA40 Front Load Washer
Door will not lock on my Hotpoint Aquarius WMA35 1100 Spin
i would get a new door or catch from the hotpoint website hope this helps
Jan 24, 2009 | Hotpoint WMA40 Front Load Washer
The door locked light will not go on.
If the door locked light is flashing, then in all probability, the main p.c.b board has blown due to a motor fault which caused the fuse to blow in the first case..
If no llight at all, then could be broken door latch or spring. If you pull on the handle and it feels sloppy , then that is where your problem is, it is not very often a door lock fails on one of these m/c's.
Plz rate my solution
Thanks.
Dec 29, 2008 | Hotpoint WMA40 Front Load Washer
Hotpoint WMA40 Front Load Washer Logo
43 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
