Amilo pa 2510
When i press and hold power button lED lights are flickering(turns on and off quickly). plz help, what might be the problem
  • 2,509 Answers
It could be anything, Start with the basics. You may have a power problem Try removing the battery, and run with just the supply. Is the supply OK? Is the battery charging?
Posted on May 14, 2014
  • 36 Answers
SOURCE: Laptop stuck in sleep / hibernate mode??
Try holding the power button down for at least 10 seconds, that should turn off the laptop completely. Then press the power button again to turn it on. Hopefully it will boot up.
Posted on May 19, 2008
SOURCE: my toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
Posted on Sep 30, 2008
Exidous
  • 63 Answers
SOURCE: Fujitsu Siemens Amilo Pro V2055 laptop power on problem
Check to see if the ram is securely in place. (that will cause a pc to not boot, usually there is a beep code tho)
Posted on Oct 06, 2008
SOURCE: hp dv2000 won't turn on...
dude, I almost gave up.. try this link. Apparently lots of people experienced this problem so HP gave an extended warranty for models like these.
Here, more info: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
To contact HP in North America call 1-866-671-7362 from 6:00 am to 11:00 pm MST, 7 days a week.
Posted on Nov 29, 2008
  • 1456 Answers
SOURCE: Hi my HP G6000 laptop wont turn on, when i press
Hi
The problem is from either the battery or the adapter .This is how to know;
First remove the battery of your laptop,plug the adapter,connect to electricity and put it on If the laptop turns on, then the battery is faulty and should be changed
If it doesn't come on,test it with another adapter. If it comes on then the adapter is faulty and you should get a new one
Cheers!!
Posted on Mar 03, 2010
Amilo pa 2510 will not turn on when i press the power button.two flash will come and go on the indicator light .what might be the problem
try taking out and reseating the ram sticks - if that doesn't work there is probably a motherboard fault.
you could also try asking on fujitsu siemens forums
Nov 03, 2014 | Fujitsu Siemens Amilo PA2510 Laptop...
How do i get the codes for a GE universal tv remote
You can programme your remote by below method
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Dec 10, 2010 | GE Televison & Video
Codes for ge universal tv remote and how do i program it?
Manual code entry
Auto configuration
Thanx
Oct 05, 2010 | GE Televison & Video
I need the codes for a magnavox
Manual code entry
Auto configuration
Thank You
Sep 19, 2010 | Universal Remote Control GE174Universal...
I would like to help me program my remote control my TV, I hope is a trademark relistic solve my problem thanks
Manual code entry
Auto configuration
Thanx
Aug 07, 2010 | GE JASRM24912 Remote Control
GEI have a ge remote with no instructions It hast these numbers inside it rc24912-e and #jc022 can you help me?
Manual code entry
Auto configuration
Thanx
Aug 07, 2010 | GE Televison & Video
I don't know the code or how to program it to my magnavox tv or zenith dvd/VCR player
Manual code entry
Auto configuration
Thanx
Aug 05, 2010 | GE RM24912 Universal Remote Control
To program my TV JVC
Manual code entry
Auto configuration
Codes for JVC TV are
3 digit codes:
013, 012, 026, 054, 055, 060, 065, 067, 069, 089, 141, 197, 247, 901
4 digit codes:
0060 0026 0197 0069 0160 0247 0923 0012 0065 0067 0141
Thanx
Aug 04, 2010 | GE JASRM24912 Remote Control
GE Universal RC24929-B Need set-up code I want to be able to change channels from remote. Thank you
Manual code entry
Auto configuration
Thanx
Aug 01, 2010 | RCA RCR450 Remote Control
How do I program my ge universal remote RC24911-C? Do you know the codes?
Hi
Manual code entry
Auto configuration
You can get your codes for your device from below website
Thanx
Jul 31, 2010 | General Electric Universal Remote Control
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
