Question about Ricoh Office Equipment & Supplies
Ricoh 25513 error sc401 - Ricoh Office Equipment & Supplies
    New Friend:
  • Ricoh Expert
  • 164 Answers
Transfer roller area leaking current. clean the area around it of devlp powder causing it to short to ground and change transfer roller and bushings. hope this helps
Posted on Aug 27, 2014
2 Suggested Answers
  • 34 Answers
SOURCE: Ricoh W2400 error SC401
The machine has a dirty ID sensor that must be cleaned. It can be cleaned without removing anything from the machine if you are very careful. Open the clamshell to access the drum area. The sensor is located in the middle of the guide plate on the front side of the drum. If you can get a soft cloth between that guide and the drum, wipe that section very carefully.
Posted on Mar 12, 2011
Error Code SC 401
1. Check the transfer unit is set correctly.
2. Check the transfer roller is set correctly.
3. Check the high voltage supply board is set correctly.
4. Check the harness of the high voltage supply board.
5. Call a Ricoh Service tech.
Aug 14, 2014 | Ricoh Aficio Mp 3352 B&w Copier
Error code SC401
  • High voltage supply board set incorrectly or defective
  • Transfer roller set incorrectly or damaged
  • Transfer unit set incorrectly
  • Aug 14, 2014 | Ricoh Aficio Mp 3352 B&w Copier
    Ricoh Aficio MP 3352 error code SC401
    Check to see if the transfer roller fell out of its holders. It is the black roller mounted on the right hand door when open.
    Aug 14, 2014 | Ricoh Aficio Office Equipment & Supplies
    What error sc401?
    Transfer roller positive error problem
    Sep 09, 2012 | Ricoh Aficio MP 2000 Black and White...
    Code SC401-00 on Ricoh 2400w
    That is a code of bad reading in the ID sensor. This sensor reads the density of toner on the Drum.
    Probably its dirty (on the worst case is broken).
    I advise you to clean it to see if it works.
    If doesn't work i advise to call your technical support (if you do not have technical skils)
    Mar 23, 2011 | Savin Office Equipment & Supplies
    Feb 23, 2011 | Ricoh - RW-240 Print Controller - 411737
    Wha tis the error code sc401 in ricoh 2400 plotter
    there could be following three possibilities
    SC401 Transfer Output Abnormal SC401- Transfer Roller Leak Detected SC401- Transfer Roller Leak
    for more detail click http://www.smilecopy.com/download/greske.pdf
    hope it helps
    if so, do rate the solution
    Nov 28, 2010 | Ricoh Office Equipment & Supplies
    My Ricoh 2232c copier has displayed error SC374 can you tell me what this means?
    SC322 Laser synchronization error SC324 LD drive current over SC390 TD sensor error 1 SC374 Development bias leak SC393 TD sensor error 2 SC401 Transfer roller leak error 1
    Jan 14, 2010 | Ricoh Aficio 2232C Color Copier
    My Rico Aficio 200
    Please open the front door and turn the blue lever in the middle,
    remove the Transfer and Separation unit and check if the bushings of the transfer roller are damaged.
    If OK, please give some oil on the shaft/bushings of the transfer roller. This unit may be replaced as a whole unit.
    If SC401 re-occurs, please check the Photoconductor unit (drum).
    Aug 27, 2008 | Ricoh Aficio 180 Laser Printer
    Gestetner 3225
    SC401: Transfer roller leak error 1
    SC402: Transfer roller leak error 2
    -Definition- [B]
    A transfer roller current leak signal is detected.
    The current feedback signal for the transfer roller is not detected.
    - Possible causes -
    · High voltage supply board defective
    · Poor connection of the PCU
    · Transfer/separation unit set incorrectly
    Jul 23, 2008 | Gestetner DSm618 All-In-One Printer
    65 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    Adorjani Laszlo
    quennie732
    OfficeServiceAjnc
    OfficeServiceAjnc
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
