Question about Cps Products VG200 Digital Vacuum Gauge
Wat is wrong cps vg200 - Cps Products VG200 Digital Vacuum Gauge
My car wont start
check the timing with a timing light
Dec 12, 2011 | Cars & Trucks
Print quality - what is hsd, nlq, utl, ssd mean on the printer
Hi Teresa,
These are just print quality settings
Super Speed Draft (SSD) - 435 cps. High Speed Draft (HSD) - 390 cps. Utility ( UTL) - 300 cps. Near Letter Quality (NLQ) - 75 cps
Hope this helps!
Please don't forget to rate
Jan 21, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
1998 intrepid , ill be driving and all the sudde ill fell a little flutter in the motor , engine light comes on and car stalls out wait about half an hour and it starts up and runs fine . ive been told...
Hi!!
This type of vehicles do have the problems you mentioned, CPS, CKP, IAC solenoid, together with the coolant leak on top of engine and the crack of the coolant reservoir tank. I am telling you this as an Intrepid owner.
Check fuel pump pressure, if don't have a gauge, borrow one from AutoZone or similar AutoParts. Also check it when engine don't start. If OK, check for spark, could be camshaft sensor (CPS).
Good Luck!! Rate this post!!
Aug 14, 2010 | 1998 Dodge Intrepid
Turnd off whrn it was on
Check the CPS...crank position sensor.
May 16, 2010 | 2000 Cadillac Catera
Turns green then turns off wats wrong and how
Well it seems you might have an issue with your video board. They run around $180.00
Aug 19, 2009 | Televison & Video
INTEL BOXD845GVSRL board doesn't turns on and gives beeps.
please check your processor and or the cooling fan, remove it and blow it very well and place back that is where such problems comes from if not change your board it might be ba, thanks
Jul 11, 2009 | Computers & Internet
2002 saturn vue
Cause of the problem:
During a non-related visit to the Saturn dealer, ie for an oil change, the Saturn dealer loosened the center of three bolts that electrically connect the main battery plus cable to the main fuse box, driver side, under hood, near windshield.
Affect of loose electrical plus cable
A loose cable, probably on the way home from the oil change, causes electrical surges that destroy the CPS and result in catastropic engine failure.
Fix:
Replace the cps. Available only from the Saturn dealer, the new cps exchange will also result in catastrophic failure when replaced.
Problem with CPS Replacement:
The Saturn dealer will bend down one of the electrical conductors on the electrical connector to the new cps. Upon insertion of the electrical connector into the cps recepticle, the bent pen will defeat cps funcetion.
Fix for the Fix
Straighten each electrical pen to the new Saturn supplied cps. Carefully reconnect the connector to the cps making certain each pen is properly inserted.
Be sure to tighten the plus center connector that holds the main fuse box firmly connected to the main plus battery cable.
Saturn will make you pay dearly and ruin your VUE engine because you shame shame shame on you because you did not pay Saturn the big bucks demanded by Saturn to renew the inadequate Saturn maintenance agreement.
Aug 19, 2008 | 2002 Saturn VUE
Cps Products VG200 Digital Vacuum Gauge Logo
44 people viewed this question
Top Cps Products Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cps Products Measuring Tool and Sensor Expert? Answer questions, earn points and help others
