Question about Fluke Networks AIRCHECK WIFI TESTER PC Notebook
Wifi air check white screen - Fluke Networks AIRCHECK WIFI TESTER PC Notebook
Why did screen turn white?
probably a connection problem with the board inside,below is a link of how it could possibly be fixed
Android Tablet White Screen fix
White screen and lines on tablet repair no video Fix it Fik
Jan 30, 2016 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
My tablet was working fine when I brought it from Amazon now it won't coonect to my wifi it says establish reliable connection to the server, I tried other WiFi connections same message
Go to your setup setting and check your wifi setup might have change because it not storing the setting might have a problem with the tablet would replace if under warranty
Apr 20, 2015 | ProntoTec 7 Inch HD 1024x600 Capacitive...
Cant connect to wifi because bluetooh is stuck running a prograhm
You can turn off BlueTooth by either going to Settings-->Bluetooth, or touching the BlueTooth icon in the Control Center (swipe bottom to center to bring up the Control Center).
Test your WiFi. If it doesn't work, double-click the Home button, locate the program BlueTooth is running, and swipe it to the top of the screen.
Test WiFi again. If it doesn't work, power down; wait 5 minutes; and power up your phone (if you don't see the white Apple icon when powering up, you did not power down properly).
Feb 15, 2015 | Apple Iphone 4s I Phone 4 S Factory...
Hp 650 blank white screen
You may want to check using an external monitor.
The DV6000 series unit have problems with Video GPUs processors. If you have experienced any other kind of issues like the WiFi not working ect. you may have a bad GPU.
Try re-seating the GPU with heat gun ( View on Utube )
Hope this helps
Apr 09, 2014 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Ipad 2 needs replacement glass or repair
Tricky repair, several ribbon cables to be aware of as they are easy to damage when removing old digitizer. It is best to take to a cell phone repair shop for the repair. If you are confident you can handle the repair yourself, there are several great videos on YouTube to get you pointed in the right direction. If you put in iPad 2 screen replacement in the YouTube search window it should pull them up for you. Good luck!!!
Apr 01, 2014 | Apple ipad 2 wifi 16gb white
My zeki tablet wont rotate when you turn it
go to setting>display>rotate screen
check the box(click in box)
it'll activate auto rotate
Jan 29, 2014 | Zeki Berk Ulu 8GB 7in WiFi Android Tablet...
How can i put on wifi without internet
Wifi comes from a router that you buy when you have a modem from your internet provider. Go to a coffee shop they have free wifi most of the time.
Dec 23, 2013 | SVP 2.8" Dual SIM Quadband Q70 White with...
Broken screen
you should take it to the apple store. If they won't help you, You can try to replace the part yourself, it is available on any auction website. There is an iPad Repair service that can fix it for you, but if you're a little tech savy you should use an iPad repair guide that teaches you how to do the repair yourself.
Feb 24, 2011 | Apple iPad 32 GB WiFi Tablet PC
Fluke Networks AIRCHECK WIFI TESTER PC Notebook Logo
37 people viewed this question
Top Fluke Networks Computers & Internet Experts
David Payne
David Payne
Are you a Fluke Networks Computer and Internet Expert? Answer questions, earn points and help others
