Question about Foxconn M61PMV Motherboard
What drivers do i need for this motherboard if i install win7-64bit OS
I use an ASUS K8V-VM motherboard with AMD sepmron 2800+ processor. os is XP sp3. which vga driver do i need to install.
video card is better but here is motherboard download area driver http://support.asus.com/download.aspx?SLanguage=en&m=K8V-VM&os=17
Mar 09, 2013 | ASUS K8V-VM Motherboard
I have instaled windows 7 for my pc, but main board is not showing drivers to instal
As Windows 7 is a new OS, the disc that came with an older motherboard will not have drivers specifically designed for it. The motherboard manufacturer and/or the manufacturer of any additional hardware peripherals (printer/scanner) and cards (video/tuner) you have are responsible to provide drivers for the new OS. You will have to visit their website(s), locate the necessary drivers in their download/support area, and then install them. You will need to know the specific model and sometimes serial number of the device(s). It is very possible that if a motherboard or device is very old that the manufacturer will have discontinued driver support for it. It is very important therefore to have gathered all new drivers prior to installing a new OS, or else obtain new hardware that supports it.
Jan 05, 2012 | Asrock Computers & Internet
Im using windows 7.. after installed that os
You need to install the motherboard and all other chipset drivers for Win 7.
Jun 16, 2010 | Mercury P4VM800M7 Motherboard
AUDIO DRIVER PROBLEM
download audio driver other from h33t.com like realstek
May 04, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I Have Asus P5PE-VM motherboard and windows vista ultimate 32 bit installed on my pc. My SoundMAX Audio Driver didn't support this OS version plz help me
In this case if your sound max did not support your OS you need to Install the lower version of OS which is compatible to your soundmax driver, because higher version did not support the other driver,
Jun 30, 2009 | ASUS P5PE-VM Motherboard
Unable to load soundcard driver
After re-installing your OS, install ALL CHIPSET DRIVERS before you install the audio drivers. You need to have the chipset drivers loaded before the Audio driver if you are using onboard sound.
Apr 07, 2009 | ASUS K8S-MX Motherboard
Motherboard and OS problem
There is likely a reason that you are re-installing a OS.
Your HD is Dead.
You should buy a new Hard Drive and install the OS on that.
Another option would be ,.. you have other OS's that were not properly installed and the hard drive is telling you that there is a prob like a F6 driver issue.
Depends on what OS was installed on it to begin with.
Jan 15, 2009 | ASUS P5PE-VM Motherboard
101ggc mother board driver are not installed in vista Os
I Need sound driver Motherboard D110ggc intel orignal
Nov 06, 2008 | Intel D101GGC Motherboard
GA-8ld533 vga problem
sir when i am install xp os then the vga driver problem occur we need vga driver software
Nov 06, 2008 | Gigabyte GA-8LD533 Motherboard
Drivers problem
do you know the model number and the make on this board and i will get them for you
Nov 04, 2007 | Intel Motherboard
Foxconn M61PMV Motherboard Logo
14 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
