Question about GE (PSS26MSRSS) Side by Side Refrigerator
Temperature 94 in refrig. normal in freezer
Opened refrig door this am and got hit with a blast of hot air. there were no displays. pushed cooler on refrig and temp was 94. freezer 4 degrees, so OK.. model #pss29ngn. It is now cooling and down to 50. any ideas as to what is wrong?
  • 248 Answers
Re: temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Posted on Nov 16, 2007
0 characters
3 Points
LGHC2342LF 2 refrig/freezer
could pull a figure out of the the air *lol,( depends on the ambient temperature
Jul 09, 2015 | Frigidaire Refrigerators
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Frigidare refrig. It seems like Freezer still working but not refrig. Temp is now 56 in refrig part. Refrig is not even 2 years old. Fan seemed to be working in refrig earlier but now not at all.
check the damper vent door between the two compartments to make sure its open to let the cold air in from the freezer then make sure the evaporator fan is operating to help push air thru this door,sometimes these doors freeze shut or if its a motor driven vent door the motor could be bad too
Jan 01, 2011 | Refrigerators
Im having a problem with my refrigerator. Freezer vent has cold air refrig does not. Kids left door open on refrig yesterday for a couple hours no definet time thats when problem started. any solutionns
Sometimes the refr still will not constantly blow cold air just because it is on and does not meet the required temperature that it's set at. In most cases, for a new refr to fully cool down, it takes 24 hrs. Let it sit for at least 6 hours with the doors closed, If it hasn't cooled off then chances are that there's a problem with the compressor. Whatever you do, don't turn up the colder knob just yet. Leave it where it was and see if it cools down, you don't want to overwork the compressor trying to reach that cooler temperature.
If after the refr sits and it still doesn't cool down, chances are you're going to have to call a repair service to come and check it out.
Dec 01, 2010 | Amana AFD2535DES French Door Refrigerator
I have a profile refrigerator PDS20SCPARSS, SN TF047061. If youopen the door alot ( 4 kids) te refrigerator temp goes all the way to 60deg and the freezer goes to -30. If you don't open the door at all the...
If this is struggling to maintain temperature like this, either the system is low on gas (motor running all the time) or the fan has stopped which you should be able to hear. Make sure that the fan is not just jammed.also check the return air vent in the fridge as if this gets stuck with a spillage ie O.J. etc, the fridge cannot get air from the freezer and the freezer runs continually (-30) but the thermostat never cuts out in the fridge. Last idea most likely.
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator is staying at 50 degrees, will not get any cooler
May be your computer board, not turning on the defrost heaters in the freezer section. The freezer will eventually get warm too. Are you getting frost build-up on the rear wall of the freezer? If you are, you can temporarily solve the problem by turning off the whole refrige for a day and open up the freezer door- put towels on the floor under the freezer doors. Then turn it back on - mine worked fine again. I am currently waiting for a computer board replacement. It is behind the metal plate on the back (outside) of the cabinet. Good luck.
Sep 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Swan fridge freezer-freezer dones,nt get down to temperature but fridge is working fine.if you turn up the thermostat the fridge acts like a freezer
There is a damper door that opens and closes when you move the thermostat. I would bet the door is functioning incorrectly. All the cooling of a refrig comes from the freezer and gets blown into the refrigerator compartment. If that damper door is open too far it will have constant freezer air blowing in....and if it's not open enough obviously the refrig will not get cool. Look at the upper left corner of your refrigerator, the center rear wall of the refrig or just feel around for a vent will cool air blowing out of it......Then take it apart and see if anything is broken.
Sep 09, 2009 | Refrigerators
Outside of freezer is hot
HI thanks for the question. the heat around the cabinet and doors is normal . the heat prevents moisture from hitting a cold surface, and turning to water , which would cause water to run down the sides, rusting the hinges. thanks the appliance doc. please rate my answer. thanks.
Sep 24, 2008 | Amana ATB1935HR Top Freezer Refrigerator
Outside of refrig/freezer hot
Heat exchangers for rejecting heat to air are built into the outside walls. This is normal. Just make sure you have enough clearance for free air circulation around it.
Apr 20, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
271 people viewed this question
Top Refrigerators Experts
Vish Iyer
Vish Iyer
Todd Marr
Todd Marr
John Tripp
John Tripp
