Question about TallyGenicom 2280 Matrix Printer
My printer display Aga error when it power on, what is the solution?
  • 2,509 Answers
AGA means automatic gap adjustment, it probably means it can't handle the paper properly. try adjusting the paper carriers and reloading the paper.
Posted on May 14, 2014
1. hardware alarm in tally2280 printer 2.AGA error
  1. Switch off the printer and Clean the encoder strip ( a transparent film strip Located bellow the cartridge )
  2. switch on the printer.
  3. if the problem is still there contact tally Service team.
Jun 02, 2011 | Tally Matrix T2280 Printer
AGA ERROR IN TALLY 2265
either your aga motor is bad or your board set is bad. Turn unit on watch the printhead while opening the cover. The printhead should move back and display "cover open". When you close cover the printhead should move closer to paper. If not bad aga motor or bad board set.
Dec 15, 2010 | Tally Dot Matrix T2265C Printer
T2250 giving error in harware alarm code +0000ne-w81 000 000000002 - 4032
Check whether AGA Gear working Proper or not OR giving noise after power on printer
If AGA Gear not working proper insert the steel rod in AGA gear properly
Oct 27, 2010 | Tally T2250 Matrix Printer
Hai , i have tally 2280 sprintpro printer.now it
problem with aga gear open the printer & check the white gears situated left upper of aga motor .......
or
may be aga flag missing or misalinged
Jun 29, 2010 | Tally Matrix T2280 Printer
Printer-Genicom 2280+ Printer stopped then continued working, often on LCD Hardware error. When turn on printer- on LCD AGA Error.
The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
This may be caused buy;
An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
The AGA flag becoming detached from the printer or damaged
An incorrectly fitted print head
Fault AGA sensor.
You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
To disable the AGA
Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
When the printer displays ASCII80 ASCII136 release ONLINE
Press NEXT until you see AGA
Select AGA and set this to OFF
You can then manually adjust the print head gap in the normal menu.
Menu>Adjust>Head change the value to increase or decrease the head gap as required.
Jul 21, 2009 | Tally Matrix T2280 Printer
Model T2280. How can I correct AGA error?
This is normally caused by a bag AGA sensor.
TALLYGEN 447540 AGA ASSY T2265 New
Link lists a T2265, but the sensor is the same.
Jun 08, 2009 | Tally Office Equipment & Supplies
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
Talley t2280 sprintpro giving error " Hardware Alarm +0253 094--- 114032+0377+0268
Hai
This is parhtiban
Contact NO : 09663390004
I faced same problem & I solved the issue
Solution : Replace the AGA sensor and AGA flag
Jan 17, 2008 | Tally Matrix T2280 Printer
TallyGenicom 2280 Matrix Printer Logo
80 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
