Question about Cfm Daikin R410a Split System Air Conditioner
What Can I do to fix a daikin heat pump U2 error code or do I need a serviceman?
2 Suggested Answers
jasondonohue
  • 6 Answers
SOURCE: solution for u2 error
it sound like the outdoor pcb has failed, if your unit is less then 5 years old it will be under warranty. if your unit is a rxd50/60/71jvea it will be a fan motor and pcb
Posted on Jun 20, 2012
Fix error code a5
Freeze-up protection. Check that indoor or outdoor heat exchangers are not clogged with dust or dirt. Check filters also. Reset by turning off power to system for 5 minutes and retry. If problem still exists could be a problem with refrigerant levels.
Sep 20, 2013 | Daikin ARC452A9 Replacement wireless...
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Solution for u2 error
Mar 16, 2012 | Cfm Daikin R410a Split System Air...
Is there a reset button on daikin splits? If so where can I find it.? Fault code U4.
the fault code for daikin u2 is power supply is too low the reason for this is complexed and needs an expert to fix it
hope this helps in some way
Dec 02, 2010 | Cfm Daikin R410a Split System Air...
How to reset the error code on daikin aircon
more info needed. try fixing the problem then turn unit of at the main power wait for 10 mins then turn on? whats the error code?
Nov 06, 2010 | Cfm Daikin R410a Split System Air...
I have daikin air con brc1c51/61 showing error code J2.
you cannot fix this mate... you will need a fridge mechanic.. try cleaning your filters id say that's your only chance
Nov 11, 2009 | Heating & Cooling
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Cfm Daikin R410a Split System Air Conditioner Logo
50 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Donni Steen
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
