Question about Neff Flava Watch Watches
Neff flava set alarm - Neff Flava Watch Watches
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
How do i turn off alarm on my neff flava watch ?
Here is a YT video that is helpful for this question:
Neff Flava Watch SKU 7879816
answers can be found here:
How to change time on neff flava watch
Apr 13, 2015 | Neff Flava Green
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    I bought a Neff daily black analog watch at Zumiez about a month ago as a present for a friend. the problem is that the minute hand and hour hand do not move... you can move them to set the time but once...
    I would take it into a jeweler and they will put a new battery in it for $4. If that fixes it all well and good, if not it cost you 4 bucks to prove it needs to go back under warranty.
    Feb 06, 2014 | Neff Daily Sucker Blue & Black Analog...
    Date does not change after 12:00 am
    Does it change at all? You may just have to set the time 12 hours later so it changes at midnight not lunch time
    Nov 30, 2013 | Neff Flava White Digital Watch
    Neff recon watch time adjustment
    I have the neff recon watch and didn't get the set up paper's for it so I can't set it. Can u send me the set up paper's?
    uploadserror please enter an image url (gif, jpg, png).
    Aug 12, 2013 | Neff Watches
    Date is wrong on neff watch
    Keep pressing mode until you get to where you get to edit the time and press the "light" button until there's a big number and that's the month and keep pressing the light button and you can edit the date and what day it is
    Dec 16, 2012 | Neff Flava Watch Watches
    Alarm
    So the alarm setting is just hidden. To unhide it, just go to the time menu and hold set. With the flashing time, scroll through the menus with the mode button until you get to alarm 1. Then press start/split to unhide it. You can also hide or unhide any of the other menus along the way.
    Aug 15, 2008 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
    Watch isn't recognised by computer
    Hi Hoffman518,
    To set the alarm on your Timex Ironman, please follow the steps below.
    1. Begin by pressing the "mode" button until the alarm screen appears.
    2. Press the "set" button and use the "advance" button to set the hour for your alarm.
    3. Repeat the same procedure to set minutes and seconds for your alarm.
    4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
    5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
    Hope it helps.
    Thank you for using FixYa.
    Aug 08, 2007 | Timex Ironman 53151 Wrist Watch
    Neff Flava Watch Watches Logo
    Top Neff Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Neff Watch Expert? Answer questions, earn points and help others
