Question about HP xw4600 Workstation with 80 PLUS Energy Efficient ChassisRB508UTABA PC Desktop
Xw4600 nonpaged bluescreen
Hp e93839
~Somewhere, over the rainbow~
My understanding by a search on the internet, is that the HP XW4600, uses a version of an Intel X38 motherboard, and has the ID numbers - model fmb-0702 - on it, as well as - e93839 -
http://h30499.www3.hp.com/t5/Workstations-z-series-xw-series/XW4600-Motherboard-Control-Panel-Schematic/td-p/1007169
7th post down, - jondvd - 09-28-2008
http://www.ebay.com/itm/HP-XW4600-Motherboard-441449-001-441418-001-/360653087990?pt=Motherboards&hash=item53f89964f6
If this holds to be true, the BLUE header, below the CMOS battery, and close to the outside edge of the motherboard, is ONE USB header.
Indicates Internal.
The Yellow header to the right of it, is the Front Panel USB header.
EACH USB header has contact pins on it, for TWO USB ports.
Does not matter which USB header we are talking about here, on that motherboard.
To identify the pinout, look for the missing pin in the header.
This is the KEY pin.
http://www.motherboardpoint.com/front-usb-pinout-compaq-evo-d310-t153627.html
http://pinouts.ws/usb-pinout.html
Regards,
joecoolvette
May 14, 2013 | Computers & Internet
Page in fault in nonpaged area
you have a faulty RAM. try switching it with a new one, it should solve your problem
May 23, 2017 | Acer Aspire One Netbook
When I plug in my headphones into the earphone jack on the HP xw4600 workstaion and play music i can hear the music from the 2.1 speaker
If you are saying when earphone plug is inserted you still have sound from speakers either jack on headphones is wrong(stereo or mono?) or the socket the jack plugs into is defective---when a jack is inserted it moves a leaf in the socket to turn the main speakers off.
May 17, 2012 | HP Computers & Internet
When I plug in my headphones into the earphone jack on the HP xw4600 workstaion and play music i can hear the music from the internal speaker. I need to disable the internal speaker so I can only hear it...
On a windows system:
Go to your control panel in the start menu.
Select "Sound"
Highlight the Speaker that you would like to modify the settings for, and click "properties"
In the "Levels" tab, move the bar to change the volume of the selected speaker.
Good Luck!
Apr 22, 2011 | HP xw4600 Workstation Linux Installer...
What type cable do I need to connect the monitor to a hp xw4600 computer?
An out of the box HP xw4600 has a NVIDIA Quadro FX1700 video card which uses a DVI cable. You have to make sure your monitor supports DVI. A WHITE connector is for DVI while a BLUE connector is for VGA. Some monitors have both while many older models only support VGA.
Oct 29, 2010 | HP xw4600 Workstation Linux Installer...
Bluescreened a few times and went out? I updated
Try testing the memory modules 1 at a time to check for faults. Bluescreens are commonly caused by bad memory especially with XP.
Dec 08, 2009 | MSI K8N Neo3 Motherboard
Page fault in nonpage area
Restart the Computer and keep tapping the F8 key for 5 to 7 seconds to display the Advanced Boot Option screen. On that screen, select "Last Known Good Configuration" option. Furthermore, if you've installed any new hardware then uninstall it.
Once the Computer is able to boot successfully, run "chkdsk /f /r" utility to detect and repair any disk errors.
Faulty hardware, a buggy system service, anti-virus software, and a corrupted NTFS volume can all generate this type of error.
Aug 29, 2009 | Computers & Internet
HP xw4600 Workstation with 80 PLUS Energy Efficient ChassisRB508UTABA  PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
